17060 Discussions
Using Intel performance maximizer questions
JazzN7
I read the user guide but I'm confused on some aspects.
I have an i9-11900k and ran the program for this processor. Had no issues for the most part.
Should I run this program with Adaptive boost enabled? or enable adaptive boost now that I have ran it? Should I use XTU optimize also after then fact? Sorry for the multiple questions, I'm just trying to figure out additional steps to increase performance.
Jean_Intel
Hello JazzN7,
We have the article Overclock Your CPU Using Intel® Performance Maximizer. It has information about the suggested steps about how to install the Intel® Performance Maximizer.
https://www.intel.com/content/www/us/en/gaming/resources/performance-maximizer.html
There is no information about enabling the Intel® Adaptive Boost Technology (Intel® ABT) after or before the Intel® Performance Maximizer. However, you must consider that adding higher frequencies to the processor may affect performance.
About your question about the usage of the Intel® Extreme Tuning Utility (Intel® XTU), it is recommended to use it for checking your system performance by stress-testing and monitoring your Intel® CPU. Again if you set higher frequencies, your system performance may be affected.
Jean O.
Jean_Intel
Hello JazzN7,
I hope you are doing fine.
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
JazzN7
When I ran IPM with ABT enabled it would fail.
