Processors
14642 Discussions
XTU 6.0.2.2 problems no showing information, can't benchmark norton reports virus also
PDeSi
1. I just installed 6.0.2.2 on two machines, in both cases Norton reported a virus in one of the files.
2. I put XTU in the Startup folder, but it doesn't start with the computer
3. Run Benchmark, reports Error Log, The benchmarking process has failed and no score was generated as a result
4. Monitoring only shows CPU Utilization and Memory Utilization
I tried reinstalling without Norton active, but the same problems.
I have the latest version of Norton Security installed.
Peter
Anonymous
Not applicable
The Intel® Extreme Tuning Utility (Intel® XTU) version 6.0.2.2 works with extreme processors only. I recommend you to uninstall and delete the current version from your computer and install it again using the file from the link below.
XTU-Setup-exe.exe
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU-
If you are running Microsoft® Windows 7, please follow the steps below.
https://downloadmirror.intel.com/24075/eng/XTU-6_0-HF1-ReleaseNotes.pdf https://downloadmirror.intel.com/24075/eng/XTU-6_0-HF1-ReleaseNotes.pdf
In regards the virus issue, you can try with McAfee trial version.
http://home.mcafee.com/downloads/OneClickTrial.aspx Antivirus Software and Internet Security For Your PC or Mac | McAfee
PDeSi
The download link takes me to 6.0.2.2, it sounds like I need to use version 5. Is there anyway to download that?
I have tried reinstalling using the file at the link provided and it always does the same thing.
Kevin_M_Intel
At this point the version 6.0.2.2 is the only one we have available to download.
As previously mentioned by Mike, the Intel XTU will work correctly with unlocked processors so I would like to know what the processor model you have is?
Kevin M
