Processors
14581 Discussions
XTU Doesnt work ?
BGÜND
My problem and system information above
My XTU Doesnt run. İ could not find any source about the reason. Please Help.
Thanks in advance, best regards.
IUman
Hello kskbeko,
Thank you for joining the Intel communities.
Please try uninstalling that Intel® XTU and reinstalling it, you can download the Intel® XTU here:
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- Download Intel® Extreme Tuning Utility (Intel® XTU)
Did you have problems with this software before upgrading to Windows 10 or only after you upgrade to Windows 10?
BGÜND
i tried in win7 and same problem what is the source of this error ?
IUman
In this case, the motherboard and processor that you are using does not support this software.
You will need at least a 2nd generation processor and later generations, on both mobile and desktop platforms.
You can see the Intel® motherboards supported by the Intel® Extreme Tuning Utility here:
http://www.intel.com/support/processors/tools/xtu/sb/CS-033226.htm Intel® Extreme Tuning Utility (Intel® XTU) — Product Release History
IUman
You can see on the screenshot I uploaded; those motherboards are the ones supported by the Intel® Extreme Tuning Utility.
It will be on the bottom of the page.
The Intel® XTU works based on the BIOS you have, and the BIOS version for this motherboard is old and there is not an Intel® XTU version available for it.
ppara5
Valued Contributor I
According to http://www.intel.com/support/motherboards/desktop/sb/CS-031689.htm?wapkw=performance+tuning+guide Desktop Boards — Performance Tuning Guides, the following boards have a Performance Tuning Guide: DZ87KLT-75K, DZ77GA-70K & DZ77RE-75K, DP67BG, DH67BL, DX58SO2 & DX58OG, and DP55KG & DP55SB. This leads one to assume that these boards will run XTU, which pre-6.0.2.8 ran fairly well on DH67BL / DH67CL, but of course only graphics OC was allowed by the chipset. XTU 6.0.2.8 no longer displays temperature or throttling status, nor does it allow for a benchmark to be run, which it did before on DH67BL / DH67CL. If only the aforementioned five boards were ever supported, the same message the OP saw should have been displayed on DH67BL / DH67CL using either 6.0.2.8 or previous versions of XTU.
BGÜND
Thanks all of yours reply and answers. İ tought i will going to renew all my mobo, cpu and rams. i brusted up already. Only thing that i wish is manufacturers and developers consider that support for they early expensive (For my country) pruducts.
Best Regards.
IUman
Thanks paramountain for the information you kindly provided!
