17515 Discussions
brand string fail test
hpoel
run diagnostic on processor got a brand string fail result from what i can get out of it it is a config issue also core 2 duo 64 bit capable yet cant get win 7 64 to load
Thank you very much for taking the time to reach the Intel Communities Team, seawolf21. I will do my best to assist you further.
When the Brand String test fails, it is basically that the processor's name was not recognized by the Intel® Processor Diagnostics Tool. Please refer to the https://www.intel.com/content/dam/support/us/en/documents/processors/sb/theintelprocessordiagnostictoolinwindowsuserguider.pdf Intel® Processor Diagnostic Tool User Guide page 20.
This does not mean that your processor is defective. In order to complete the test on the IPDT go Tools > Stop Testing On Fail > Off.
Can you please provide us the model of your processor and motherboard?
Antony S.
hpoel
i will get back to you on board and cpu had a catastrophic accident with that computer so now using one even older i get 600 a month on disability so both machines are dump rescues i want to cry lol won't give up hope though give me a couple days.
Hello, seawolf21.
I would like to know if you could perform the troubleshooting steps provided?
Antony S.
ANovi3
Hello! I have the same isue. But also i have problem with temperature monitor. i need to disable both of them in 'tools' before run the test.
pentium d945
asus p5ld2
monitoring of the temperature works in bios and third party software developer on Windows 10, but it does not with genuine intel processor utility)))
also i have changed all settings in bios that required utility from help paper
actualy i have not much of them:
max cpuid value - disabled
thermal monitor - enabled
c1 control - enabled
speed step - disabled
microcode updation - enabled
execute disable bit - enabled
any suggestions???
Thank you very much for joining this thread, artnovich.
In this case, if the troubleshooting steps above did not work for you I will highly recommend you to create a new thread explaining your problem. Make sure you include your system configuration and a clear explanation about the issue so we can give you a solution as soon as possible.
Antony S.
bnet0
After install IPDT in folder "BrandString_LocalConfig.xml" change name for core 2 duo processor. Corect name is -CoreStringParts = "Intel(R)|Core(TM)2|CPU|@"
APaes
Worked perfectly for me. Thank you.
ASHISH6
INTEL Core Duo E8400 using 2+ years
Socket LGA 775
Mother Board
JOYOON IPM41-D3
RAM
DDR3 2+2 GB
Specifications regarding all components are attached below in PDF format.
It doesn't start on the first attempt in the morning pressing the power key on the CPU (Except the processor fan and other things like SMPS CPU light turn on). The processor turns on after pressing the restart key a few times. But in the daytime, it doesn't happen at all.
Is it a processor issue or the CPU power switch or due to dust it happened?
My Intel Diagnostic tool Test report is shared below.
--- IPDT - Revision: 4.1.7.39
--- IPDT - Start Time: 28-05-2023 12:00:26
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Fail.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - IMC - Pass.
CPU 1 - Prime Number - Pass.
CPU 1 - Floating Point - Pass.
CPU 1 - Math - Pass.
CPU 1 - GPU Math - Pass.
CPU 1 - CPULoad - Pass.
CPU 1 - CPUFreq - Pass.
IPDT Failed
--- IPDT - End Time: 28-05-2023 12:04:25
FAIL
AlHill
You can ignore this error on a processor from 2008.
Hello, seawolf21.
I would like to know if you still need assistance? If so, please do not hesitate to reply to my previous post.
Antony S.
RGohi1
Hello! I have the same issue.
--- IPDT - Revision: 4.1.4.36
--- IPDT - Start Time: 15-06-2020 17:04:15
CPU1
CPU Brand String Test
Module Version: 1.0.20.32b.W
Start Time: Mon Jun 15 17:04:17 2020
Test Result - FAIL
..no valid string parts found..
Detected: Intel(R) Core(TM)2 Duo CPU   E7200 @ 2.53GHz
String part compare error
End Time: Mon Jun 15 17:04:17 2020
Total Time: seconds: 0
System Information
Processor Name: Intel(R) Core(TM)2 Duo CPU   E7200 @ 2.53GHz
Processor Information: Family 6 Model 23 Stepping 6
Number of Physical Cores: 2
Number of Logical Cores: 2
Operating System: Microsoft Windows 10 Pro 32-bit
Graphics Information: NVIDIA GeForce 8400 GS
--- IPDT - End Time: 15-06-2020 17:08:48
--- IPDT - Result: Fail
AlHill
This thread is more than two years old.
For your processor E7200, it is going to fail on Brand String test as your processor is simply too old.
Ignore the error - there is nothing wrong.
Doc
