Processors
14669 Discussions
i7 2600k temperature 98c
i've a i7 2600k @3,40 stock frequency and stock cooler, on a sabertooth p67, 2x4gb Kingston hyper-x 1600Mhz.
In idle temperatures are 50° celsius on cores and in full load with prim95 98° celsius!!! I reseated the cooler, changed TIM, but with no effect. The cooler has no movements. In the bios i've enabled X.M.P for 1600mhz ddr3. If i change in from X.M.P to auto, max temp is 91 degrees that is also very hot.
http://img7.imageshack.us/img7/3475/temphm.th.jpg
My uncle and my cousin have same configuration, same motherboard and same cpu and temp are not higher than 79 -80 degrees with the same ambient temperature of 28-30 ° clesius.
Is my cpu defective?
Adolfo_S_Intel2
It seems that you are reading the cores temperature, you do not need to worry about the cores temperature, but instead you need to pay attention to the CPU temperature itself.
Please check with the motherboard manufacturer for them to provide you monitoring software that can provide CPU temperature instead of cores temperature.
As long as your CPU temperature does not reach above 72.6 degrees Celsius, the processor will be running under thermal specifications.
With Asus thermal radar cpu temp with x.m.p is over 87 ° celsius. Without X.M.P is around 80 ° celsius. In both cases the temps are higher than 72* c.
Adolfo_S_Intel2
In this case I would suggest contacting the local support center for warranty options.
If possible test the processor on a 2nd motherboard to see if the processor has the same thermal behavior.
Local support center contact information is here:
http://www.intel.com/support/9089.htm http://www.intel.com/support/9089.htm
