16897 Discussions
i7-7820x DDR4 compatibility
JLaut
I'm building a system using the Intel i7-7820x processor on an ASRock x299 Taichi Motherboard. The only spec I can find on the processor seems to indicate that it will only handle 4 X DDR4 modules of up to 8GB each. I was planning to load two modules of 16GB each and need to know if this will work or not. The spec doesn't seem real clear on this. Thanks.
Hello, everyone!
BubbaB: Thank you very much for that information. That is actually correct!
Lado: Thank you very much for contacting the Intel® Communities Team. Just to 7th Generation processor. Please find the https://www.intel.com/content/www/us/en/processors/core/7th-gen-core-family-desktop-s-processor-lines-datasheet-vol-1.html 7th Generation Datasheet, page 21, 2.1.1.2 section, the processor will support 16GB on each DIMM. Bear in mind that this specific processor will support DDR4-2666 and I recommend you to have the XMP option activated on your Motherboard's BIOS.
Antony S.
AW4
Where did you find that this cpu can only handle 4 memory modules of 8GB each?
The motherboard (and cpu) can handle 8 memory modules of 16GB each for a total of 128GB.
https://ark.intel.com/products/123767/Intel-Core-i7-7820X-X-series-Processor-11M-Cache-up-to-4_30-GHz Intel® Core™ i7-7820X X-series Processor (11M Cache, up to 4.30 GHz) Product Specifications
  • Max Memory Size (dependent on memory type)128 GB
  • Memory TypesDDR4-2666
  • Max # of Memory Channels4
https://www.asrock.com/mb/Intel/X299%20Taichi/index.asp# Specification ASRock > X299 Taichi
- 8 x DDR4 DIMM Slots
Max. capacity of system memory: 128GB
JLaut
Bubba, Thanks for the quick response. On Intel's website the i7-7820x is not listed under the 8th generation processors, so I clicked on the "x-series" and found it listed there. Oddly, when I downloaded the datasheet it was labeled "6th-gen-x-series-processors". On page 7 is states "It features and Integrated Memory Controller (IMC) that supports 4 channels of DDR4 memory". I assumed incorrectly that the term "channels" referred to the actual DIMM slots on the motherboard - which I believe now is actually speaking of "quad channel memory". However, on page 9, it states, "supports 4 DDR channels" and "4GB and 8GB DDR4 DRAM technologies supported for these devices: UDIMM x8".
I know my motherboard specs and I bought the 7820x processor with the understanding that it would support the G. Skill 32GB (2 x 16GB) DDR4 2400MHz I bought - planning to add more in the future as needed for audio production work. But the statement on page 9 about the GB supported threw me and I still don't understand it. I just want to know that the processor will support the 16GB DDR4 memory in each DIMM slot. Thanks for helping clarify this.
Hello, everyone!
Antony S.
JLaut
Anthony,
Perhaps you didn't read my original message. The processor in question is not 7th gen. It is 8th (i7-7820x). Please address my issue with this particular processor.
Thank you. Lado
Thank you very much for your prompt reply, Lado.
Allow me to share with you that the https://ark.intel.com/products/123767/Intel-Core-i7-7820X-X-series-Processor-11M-Cache-up-to-4_30-GHz Intel® Core™ i7-7820 belongs to the https://ark.intel.com/products/codename/37572/Skylake Skylake family which is the code name for the 7th Generation processors. Please find the Coffe Lake (8th Generation) processors in the following link: https://ark.intel.com/products/codename/97787/Coffee-Lake https://ark.intel.com/products/codename/97787/Coffee-Lake
Antony S.
