Processors
14753 Discussions
i7 vs Pentium 2200
I'm looking to replace a desktop running a 2.2 ghz Pentium dual CPU E2200 with an HP dv7-4071nr laptop with an i7 720 chip. My question is this: will the i7 720 be a faster machine even though it's only 1.6 ghz? The laptop will run biz programs like Office 2010, quickbooks, etc. No gaming or video making, etc. Thanks for your response.
If you're going to use only office applications then it's better to go with dual-core processors like Core I7-620M or I5-540M, than with quad-core Core i7-720QM. Your programs probably won't use all cores on the i7-720QM, and for single- and dual-threaded tasks dual-cores are faster. From the page below you can see that with/without Turbo Boost the i7-620M has higher or much higher clock frequency than the i7-720QM:
http://www.cpu-world.com/Compare/291/Intel_Core_i7_Mobile_I7-720QM_vs_Intel_Core_i7_Mobile_i7-620M_%28PGA988%29.html
Also, CPU is not the only factor in determining whether new system will be faster than the old one or not. Amount of RAM, type of hard disk and model of video card are important too. Well, in your case video card is not important. Make sure you get as much RAM as you had in your desktop system.
Gennadiy
