i have recently built my first pc, in the bios it says that my e8400 temp is 42.5/C is this an acceptable temp or is it overheating. I have yet to install the os and drivers but want to be sure that everything is ok first, as I have said i'm new to all this so any info is gratefully received cheers
That is normal. The real question is what it does on 100% load (ala, maxing out the processor). You can use a utility like wPrime to do that.
The stock cooler is usually fine, but you may want to pick a 3rd party cooler if you intend to overclock.
thanks Evaders99 youve put my mind at rest, ill check out wPrime as well cheers
