Hi all,
I get the following warnings and error, I'm assuming the server lines problem is due to using a floating licence key but it not being on a server (long story of confusion by various people resulted in our original node locked license getting replaced by a floating one without having a floating license server!) Warning: Support for IP core ALSE_MIIM (7D3A_001B) in device family Cyclone III is preliminary and specifications are subject to change Warning: FLEXlm software error: No SERVER lines in license file Feature: 7D3A_001B License path: D:\xxx\xxx\00xx50xx75xx__0.dat FLEXlm error: -13,128 For further information, refer to the FLEXlm End User Manual, available at "www macrovision com". Warning: FLEXlm software error: No SERVER lines in license file Feature: 7D3A_001B License path: D:\xxx\xxx\00xx50xx75xx__0.dat FLEXlm error: -13,128 For further information, refer to the FLEXlm End User Manual, available at "www macrovision com". Error (10003): Can't open encrypted VHDL or Verilog HDL file "D:/x/miim/AVALON_MIIM_01.00.vhd" -- current license file does not contain a valid license for encrypted file Will either getting a node locked license or setting up a floating license server resolve the error? Any guidance would be most helpful. DaveLink Copied
