20735 Discussions
Allow Any Shift Register Size for Recongnition Option On/Off
Hi!Everybody!
I am confused by the Allow Any Shift Register Size for Recongnition Option in the more settings of Compilation & Analysis settings.
The following is the resource code.
module test(clk,shift,sr_in,sr_out);
input clk,shift;
input sr_in;
output sr_out;
reg [63:0]shift_reg;
always @(posedge clk)
begin
if (shift==1'b1)
shift_reg[63:1] <= shift_reg[62:0];
shift_reg[0] <= sr_in;
end
assign sr_out = shift_reg[63];
endmodule
As we all know,It's only a Signal-Bit Wide,64-Bit Shift Register.I am confused by that when I set the Allow Any Shift Register Size for Recongnition Option to "ON", the using resource make me very surprise,this is the printscreen:
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_2on.png
However, when I set the Allow Any Shift Register Size for Recongnition Option to "OFF", the following is the printscreen of Compilation report:
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_2off.png
I think,when I set the Allow Any Shift Register Size for Recongnition Option to "ON", Quartus II should use registers to implement it, not combinational logic or Memory bits, and when I set the Option to "OFF", Either registers or combinational logic is possible , So Can you tell me the reason between the two compilation report, thanks!
Does anyone know? I need help! many thanks!
I would use RTL viewer to see how the circuit was implemented after each compile. That would shed some light on what this option is doing.
Thanks for your reply,Nails!
I did that before, there is no difference between the two sitution in RTL, but when having a look about the technology map viewer seriously, I am aware of the circuit implemented by the option(Allow any shift register size for recongnition ON) is more complex than OFF. and I am studying from it now.
By the looks of it, one method uses the on-chip memory for the 64 bit register, and the other implements it in dedicated registers.
If the schematic is truly identical, perhaps you are only looking at the highest level schematic, and need to right-click on the memory block/shift_reg register (or some other block) in the schematic to go down one heirarchy to reveal how that is implemented to see the differences.
--- Quote Start ---
--- Quote End ---
I think you're partly misunderstanding the option. shift register recognition implies putting shift registers to internal RAM, no recognition to registers. Combinational logic isn't an option for shift registers in any case. As you can see from the register and RAM resource utilization in the report, Quartus is just doing this, you don't need to review the gate level net lists.
--- Quote Start ---
--- Quote End ---
Hi! Nails!
You said"If the schematic is truly identical, perhaps you are only looking at the highest level schematic, and need to right-click on the memory block/shift_reg register (or some other block) in the schematic to go down one heirarchy to reveal how that is implemented to see the differences."
However,there is no difference between the two RTL schematics.e.g.
This is the RTL screenprint when the option is set to ON.
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_on_rtl1.png
and when the option is set to OFF.
http://images.cnblogs.com/cnblogs_com/tdyizhen1314/257630/r_off_rtl1.png
I tried,and I knew this was the highest level schematic,but It could't go down again by right-click.
In fact, FvM had told the differences.
I was misunderstanding the option before.Thanks for your reply again!
