21602 Discussions
Altera Monitor Program Compilation Error
I am new to Altera and was trying out the tutorial downloaded from the website using Altera Monitor Program v4.1 with QuartusII 9.1 installed on Windows 7.
But I run into error "dirname: extra operand `files'. when trying to compile the source file using Altera Monitor Program v4.1. I tried a few fixes like eliminating spaces in directory path, uses a shorter path, reinstall the program, running as administrator...but it still gives the same error...
I've been struggling for a day...appreciate if someone can give a hint.
Thank you.
--Info & Error screen capture:
Compiling source files...
nios2-elf-as --gstabs -I C:/altera/91/nios2eds/components/altera_nios2/sdk/inc -I C:/mydata/test_assem C:/mydata/test_assem/getting_started.s -o C:/mydata/test_assem/getting_started.s.o
try `dirname --help' for more information
Linking...
nios2-elf-ld --defsym nasys_program_mem=0x0 --defsym nasys_data_mem=0x0 --section-start .exceptions=0x20 --section-start .reset=0x0 -e _start -u _start --script c:/altera/91/quartus/../University_Program/Monitor_Program/build/nios_as_build.ld -g -o C:/mydata/test_assem/getting_started.elf C:/mydata/test_assem/getting_started.s.o
Compilation stopped.
I think i've found the problem with the user path setting under the windows environment. Please end this thread. Thanks.
