20778 Discussions
Cordic Processor descreption VHDL
it is the cordic processor descreption with a pipline cellul, I need the VHDL descreption of package "constantes_cordic.all"
description du processeur
cordic à accumulateur
b.1 cellule du pipeline
-- description d’une cellule du pipeline
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use work.constantes_cordic.all;
entity cordic_cell is
generic (resolution : natural := out_n;
cell_id : natural := 1
port (clk, rst : in std_logic;
-- les ’signed’ sont représentés en
-- complément à 2
X1 : in signed(resolution-1 downto 0);
Y1 : in signed(resolution-1 downto 0);
Z1 : in signed(resolution-1 downto 0);
X2 : out signed(resolution-1 downto 0);
Y2 : out signed(resolution-1 downto 0);
Z2 : out signed(resolution-1 downto 0)
end entity cordic_cell;
architecture arch_cordic_cell of cordic_cell is
signal X2_t,Y2_t,Z2_t,X1_s,Y1_s,atan :
signal Z_sign : std_logic;
-- fonction décalage à droite arithmétique
-- d’amplitude n ( sur entier en complément à 2)
function rshift(val : in signed) return signed is
variable tampon : signed(val’range);
begin
for i in val’high downto val’high-cell_id+1 loop
-- on place à 0 (nbr positif) ou 1 (nbr négatif)
-- les n msbs
tampon(i):= val(val’range);
end loop;
for i in val’range-cell_id downto 0 loop
-- on décale vers la droite le reste des
-- bits
tampon(i):= val(i+cell_id);
end loop;
return tampon;
end function rshift;
-- fonction addition / soustraction
function addsub(v1 : in signed;
v2 : in signed;
sign : in std_logic)
return signed is
begin
if sign = ’1’ then
return v1+v2;
else
return v1-v2;
end if;
end function addsub;
begin
Z_sign <= Z1(resolution-1);
atan <= arctan(cell_id);
X1_s <= rshift(X1);
Y1_s <= rshift(Y1);
X2_t <= addsub(X1,Y1_s,Z_sign);
Y2_t <= addsub(Y1,X1_s,not Z_sign);
Z2_t <= addsub(Z1,atan,Z_sign);
cordic_process : process(rst,clk)
begin
if rst=’1’ then
X2 <= (others=>’0’);
Y2 <= (others=>’0’);
Z2 <= (others=>’0’);
elsif rising_edge(clk) then
X2 <= X2_t;
Y2 <= Y2_t;
Z2 <= Z2_t;
end if;
end process cordic_process;
end arch_cordic_cell;
B.2 pipeline
-- description du pipeline
library ieee;
entity cordic is
theta : in signed(out_n-1 downto 0);
rho_2 : in signed(out_n-1 downto 0);
cos : out signed(out_n-1 downto 0);
sin : out signed(out_n-1 downto 0)
end entity cordic;
architecture pipeline_simple of cordic is
-- signaux de connexion entre les différentes
-- cellules du pipeline
signal X,Y,Z : pipeline_array;
-- cellule de pipeline
component cordic_cell is
end component cordic_cell;
begin
-- correspondance des signaux
X(0) <= rho_2;
Y(0) <= (others => ’0’);
Z(0) <= theta;
cos <= X(pipeline_n);
sin <= Y(pipeline_n);
fabrication_pipeline :
for n in 1 to pipeline_n generate
pipe_cell : cordic_cell
generic map (resolution => out_n,
cell_id => n)
port map (clk => clk,
rst => rst,
X1 => X(n-1),
Y1 => Y(n-1),
Z1 => Z(n-1),
X2 => X(n),
Y2 => Y(n),
Z2 => Z(n));
end generate fabrication_pipeline;
end pipeline_simple;
