Hello everyone!
I am using altera ep2c5t144c8 mini development board to get the output of 60Hz sine wave with the carrier frequency of 20KHz. I,ve got the results of SPWM but with spikes in it and these spikes are increasing with time due to which the shape of sine wave is deforming and the wave is shifting towards right while I am giving the sine table of 1000 values in my vhdl code. Vhdl code is here....library IEEE;use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity pwm is
port (
clk : in std_logic;
reset : in std_logic;
driv1_out : out std_logic;
driv2_out : out std_logic;
driv3_out : out std_logic;
driv4_out : out std_logic;
pwm_out : out std_logic
end pwm;
architecture behavioral of pwm is
signal driv1_out_sig, driv4_out_sig : std_logic := '0';
signal driv2_out_sig, driv3_out_sig : std_logic := '1';
signal pwm_out_sig : std_logic := '0';
signal i : integer range 0 to 999:=0;
type memory_type is array (0 to 999) of integer range 0 to 2450;
signal sine : memory_type :=(0, 4, 8, 12, 15, 19, 23, 27, 31, 35, 38, 42, 46, 50, 54, 58, 62, 65, 69,
73, 77, 81, 85, 88, 92, 96, 100, 104, 108, 112, 115, 119, 123, 127, 131, 135, 138, 142, 146, 150, 154,
158, 162, 165, 169, 173, 177, 181, 185, 188, 192, 196, 200, 204, 208, 211, 215, 219, 223, 227, 231, 234,
238, 242, 246, 250, 254, 257, 261, 265, 269, 273, 276, 280, 284, 288, 292, 296, 299, 303, 307, 311, 315,
319, 322, 326, 330, 334, 338, 341, 345, 349, 353, 357, 360, 364, 368, 372, 376, 379, 383, 387, 391, 395,
398, 402, 406, 410, 414, 417, 421, 425, 429, 433, 436, 440, 444, 448, 452, 455, 459, 463, 467, 470, 474,
478, 482, 486, 489, 493, 497, 501, 504, 508, 512, 516, 519, 523, 527, 531, 534, 538, 542, 546, 549, 553,
557, 561, 564, 568, 572, 576, 579, 583, 587, 591, 594, 598, 602, 606, 609, 613, 617, 620, 624, 628, 632,
635, 639, 643, 646, 650, 654, 658, 661, 665, 669, 672, 676, 680, 684, 687, 691, 695, 698, 702, 706, 709,
713, 717, 720, 724, 728, 731, 735, 739, 742, 746, 750, 753, 757, 761, 764, 768, 772, 775, 779, 783, 786,
790, 794, 797, 801, 805, 808, 812, 815, 819, 823, 826, 830, 834, 837, 841, 844, 848, 852, 855, 859, 862,
866, 870, 873, 877, 880, 884, 888, 891, 895, 898, 902, 905, 909, 913, 916, 920, 923, 927, 930, 934, 938,
941, 945, 948, 952, 955, 959, 962, 966, 969, 973, 977, 980, 984, 987, 991, 994, 998, 1001, 1005, 1008,
1012, 1015, 1019, 1022, 1026, 1029, 1033, 1036, 1040, 1043, 1047, 1050, 1054, 1057, 1061, 1064, 1067,
1071, 1074, 1078, 1081, 1085, 1088, 1092, 1095, 1099, 1102, 1105, 1109, 1112, 1116, 1119, 1123, 1126,
1129, 1133, 1136, 1140, 1143, 1146, 1150, 1153, 1157, 1160, 1163, 1167, 1170, 1174, 1177, 1180, 1184,
1187, 1190, 1194, 1197, 1200, 1204, 1207, 1211, 1214, 1217, 1221, 1224, 1227, 1231, 1234, 1237, 1241,
1244, 1247, 1250, 1254, 1257, 1260, 1264, 1267, 1270, 1274, 1277, 1280, 1283, 1287, 1290, 1293, 1296,
1300, 1303, 1306, 1310, 1313, 1316, 1319, 1323, 1326, 1329, 1332, 1335, 1339, 1342, 1345, 1348, 1352,
1355, 1358, 1361, 1364, 1368, 1371, 1374, 1377, 1380, 1383, 1387, 1390, 1393, 1396, 1399, 1402, 1406,
1409, 1412, 1415, 1418, 1421, 1424, 1428, 1431, 1434, 1437, 1440, 1443, 1446, 1449, 1452, 1456, 1459,
1462, 1465, 1468, 1471, 1474, 1477, 1480, 1483, 1486, 1489, 1492, 1496, 1499, 1502, 1505, 1508, 1511,
1514, 1517, 1520, 1523, 1526, 1529, 1532, 1535, 1538, 1541, 1544, 1547, 1550, 1553, 1556, 1559, 1562,
1565, 1568, 1571, 1574, 1576, 1579, 1582, 1585, 1588, 1591, 1594, 1597, 1600, 1603, 1606, 1609, 1612,
1614, 1617, 1620, 1623, 1626, 1629, 1632, 1635, 1637, 1640, 1643, 1646, 1649, 1652, 1655, 1657, 1660,
1663, 1666, 1669, 1672, 1674, 1677, 1680, 1683, 1686, 1688, 1691, 1694, 1697, 1699, 1702, 1705, 1708,
1711, 1713, 1716, 1719, 1721, 1724, 1727, 1730, 1732, 1735, 1738, 1741, 1743, 1746, 1749, 1751, 1754,
1757, 1759, 1762, 1765, 1767, 1770, 1773, 1775, 1778, 1781, 1783, 1786, 1789, 1791, 1794, 1796, 1799,
1802, 1804, 1807, 1810, 1812, 1815, 1817, 1820, 1822, 1825, 1828, 1830, 1833, 1835, 1838, 1840, 1843,
1845, 1848, 1850, 1853, 1855, 1858, 1860, 1863, 1865, 1868, 1870, 1873, 1875, 1878, 1880, 1883, 1885,
1888, 1890, 1893, 1895, 1898, 1900, 1902, 1905, 1907, 1910, 1912, 1914, 1917, 1919, 1922, 1924, 1926,
1929, 1931, 1934, 1936, 1938, 1941, 1943, 1945, 1948, 1950, 1952, 1955, 1957, 1959, 1962, 1964, 1966,
1968, 1971, 1973, 1975, 1978, 1980, 1982, 1984, 1987, 1989, 1991, 1993, 1996, 1998, 2000, 2002, 2004,
2007, 2009, 2011, 2013, 2015, 2018, 2020, 2022, 2024, 2026, 2029, 2031, 2033, 2035, 2037, 2039, 2041,
2043, 2046, 2048, 2050, 2052, 2054, 2056, 2058, 2060, 2062, 2064, 2067, 2069, 2071, 2073, 2075, 2077,
2079, 2081, 2083, 2085, 2087, 2089, 2091, 2093, 2095, 2097, 2099, 2101, 2103, 2105, 2107, 2109, 2111,
2113, 2115, 2117, 2119, 2120, 2122, 2124, 2126, 2128, 2130, 2132, 2134, 2136, 2138, 2139, 2141, 2143,
2145, 2147, 2149, 2151, 2152, 2154, 2156, 2158, 2160, 2162, 2163, 2165, 2167, 2169, 2171, 2172, 2174,
2176, 2178, 2179, 2181, 2183, 2185, 2186, 2188, 2190, 2192, 2193, 2195, 2197, 2198, 2200, 2202, 2204,
2205, 2207, 2209, 2210, 2212, 2214, 2215, 2217, 2218, 2220, 2222, 2223, 2225, 2227, 2228, 2230, 2231,
2233, 2235, 2236, 2238, 2239, 2241, 2242, 2244, 2245, 2247, 2248, 2250, 2252, 2253, 2255, 2256, 2258,
2259, 2261, 2262, 2264, 2265, 2266, 2268, 2269, 2271, 2272, 2274, 2275, 2277, 2278, 2279, 2281, 2282,
2284, 2285, 2286, 2288, 2289, 2290, 2292, 2293, 2295, 2296, 2297, 2299, 2300, 2301, 2303, 2304, 2305,
2306, 2308, 2309, 2310, 2312, 2313, 2314, 2315, 2317, 2318, 2319, 2320, 2322, 2323, 2324, 2325, 2326,
2328, 2329, 2330, 2331, 2332, 2334, 2335, 2336, 2337, 2338, 2339, 2341, 2342, 2343, 2344, 2345, 2346,
2347, 2348, 2349, 2351, 2352, 2353, 2354, 2355, 2356, 2357, 2358, 2359, 2360, 2361, 2362, 2363, 2364,
2365, 2366, 2367, 2368, 2369, 2370, 2371, 2372, 2373, 2374, 2375, 2376, 2377, 2378, 2379, 2380, 2380,
2381, 2382, 2383, 2384, 2385, 2386, 2387, 2388, 2388, 2389, 2390, 2391, 2392, 2393, 2393, 2394, 2395,
2396, 2397, 2398, 2398, 2399, 2400, 2401, 2401, 2402, 2403, 2404, 2404, 2405, 2406, 2407, 2407, 2408,
2409, 2409, 2410, 2411, 2412, 2412, 2413, 2414, 2414, 2415, 2415, 2416, 2417, 2417, 2418, 2419, 2419,
2420, 2420, 2421, 2422, 2422, 2423, 2423, 2424, 2424, 2425, 2426, 2426, 2427, 2427, 2428, 2428, 2429,
2429, 2430, 2430, 2431, 2431, 2432, 2432, 2433, 2433, 2433, 2434, 2434, 2435, 2435, 2436, 2436, 2436,
2437, 2437, 2438, 2438, 2438, 2439, 2439, 2439, 2440, 2440, 2441, 2441, 2441, 2442, 2442, 2442, 2442,
2443, 2443, 2443, 2444, 2444, 2444, 2444, 2445, 2445, 2445, 2445, 2446, 2446, 2446, 2446, 2447, 2447,
2447, 2447, 2447, 2447, 2448, 2448, 2448, 2448, 2448, 2448, 2449, 2449, 2449, 2449, 2449, 2449, 2449,
2449, 2449, 2449, 2450, 2450, 2450, 2450, 2450, 2450, 2450, 2450, 2450, 2450, 2450, 2450);
begin
driv1_out <= driv1_out_sig;
driv2_out <= driv2_out_sig;
driv3_out <= driv3_out_sig;
driv4_out <= driv4_out_sig;
pwm_out <= pwm_out_sig;
process(clk)
variable count : integer range 0 to 416000;
variable counter_60hz : integer range 0 to 416000;
variable counter_pwm : integer range 0 to 2510;
variable pwm_shift_reg : integer range 0 to 2510;
variable count_sync : integer range 0 to 209;
begin
if(clk'event and clk = '1') then counter_pwm := counter_pwm +1 ; count := count + 1;
counter_60hz := counter_60hz + 1;
if(reset = '0') then
counter_pwm := 0;
count_sync := 0;
count := 0;
counter_60hz := 0;
pwm_shift_reg := 0;
i <= 0;
pwm_out_sig <= '0';
driv1_out_sig <= '0';
driv2_out_sig <= '1';
driv3_out_sig <= '1';
driv4_out_sig <= '0';
else
if (count > 416000) then
count := 0 ;
end if;
if (count < 208000) then count_sync := count_sync +1;
if(count_sync =208) then
count_sync :=0;
i <= i+ 1;
if(i = 999) then
i <= 999;
end if;
end if;
else if (count > 208000) then count_sync := count_sync +1;
count_sync :=0;
i <= i- 1;
if(i = 0) then
i <= 0;
end if;
end if;
end if;
end if;
if (counter_60hz = 416000) then
counter_60hz :=0 ;
driv1_out_sig <= not (driv1_out_sig);
driv2_out_sig <= not (driv2_out_sig);
driv3_out_sig <= not (driv3_out_sig);
driv4_out_sig <= not (driv4_out_sig);
end if;
pwm_shift_reg := sine(i);
if(counter_pwm = pwm_shift_reg ) then
pwm_out_sig <= '0';
else if(counter_pwm = 2510) then
counter_pwm := 0;
pwm_out_sig <= '1';
end if;
end if;
end if; --reset
end if; --clk
end process;
end Behavioral;
The screenshots of sine wave output which is shifting with time http://www.alteraforum.com/forum/attachment.php?attachmentid=11224&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=11225&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=11226&stc=1 How can I fix this problem? I want pure sine wave that should not vary with time which is happening in my case currently. Everyone's attention will be highly appreciable!:)
one thing I notice your counters are restrained only if equal to maximum set but they can be over max so they keep adding.
for example if(counter_pwm = 2500) then counter_pwm := 0 end if; it should be more than or equal. if you are just adding 1 that shouldn't matter but what about count which adds 83 and what is this logic meant to do: if (count < 208335) then count := 0;- Mark as New
first of all thanks for your attention Kaz!
What I can understand from ur perspective that I should write the condition like this if(counter_pwm >= 2500) then counter_pwm := 0 end if; secondly in given code the count of 208 is adding instead of 83. Now my logic is that the value '208335' is the total time in which 1/4th of the complete cycle completes and I am using 1000 values(you can see in code) which I am sending in this total time so I get the equal interval of 208 counts. In short we can say 208 is the time interval between two values of the table of 1000 values.- Mark as New
Let me focus on this issue.
if clk edge...
count := count + 83;
if reset...
count := 0;
else
count := 0;
so count starts as zero and so is always < 208335 and so should be stuck between 83 and zero. Is this really the correct copy of your code? Or am I missing something? The second issue what do mean by 60Hz and 20KHz carrier? what is your clock speed?
I am trying to make 60Hz inverter based on 20KHz carrier frequency of pulse width modulation(PWM) and clock speed is 50MHz.
I am done with it Kaz! :)
I,ve achieved pure sine wave!!! Kaz thank you so much for your help and attention towards me :)
