21144 Discussions
Difference of X-ray internal structure -#EPM3064ATC44-10N
MelodyCC
We bought some parts and issued the X-ray test on them.Result shows different internal structure at the left corner of the pics.Does anyone know the reason for this difference?
Attahced is the difference.
_AK6DN_
Valued Contributor II
Are the package markings all the same? Lot ID, date codes, etc?
Were the parts sourced from authorized vendors, or bought from random resellers?
The silicon die pad placements look identical as best as I can tell in a cursory visual inspection.
The lead frames appear slightly different.
What do you think the differences are?
Zawani_M_Intel
Hi MelodyCC,
Assume these 2 X-ray images are from same OPN, it is normal to have slight difference as one device might have 2 lead frame vendors. Each lead frame vendor's design have slight difference.
As long you get the device from Intel Authorize Distributor, there should be no issue. If there is any issue with the purchase, your Sales Team are welcome to contact your Distributor or Intel Sales Team.
Distributor Partners
Thank you!
