I use EP3CLS200, I programed the EPCS64 by AS mode, At first the program can be running normally, but yestoday I find the program can't run,
when I test the DCLK pin of EPCS64, there is no clock when I power up, but I also can programm the EPCS64 in AS mode. the 3.3v and 1.2V all ok, but I don't konw where is problem ? Thanks for you answer.Link Copied
The fpga is broken?? How can I find the problem?
I change the EPCS64, BUT the problem is also there.- Mark as New
How to test EP3CLS200 is ok?
EP3CLS200 can't access JTAG chain? message: can't configure device, expected JTAG ID 0x2077 ,but JTAG ID code 0x0000000;- Mark as New
check the jtag signals with a scope. Is the FPGA getting his 1.2 and 2.5V supplies?
1.2v and 2.5v is ok!
