I wrote a Verilog code for a CIC decimation filter. I relied on a code written in the book 'digital signal processing with FPGA' . Here is the code: // cic decimation filter : R=64, M=1, N=3 module cicdecim64 (x_in,y_out,clk,reset); input clk,reset; input [7:0] x_in; output [7:0] y_out; parameter hold=0, sample=1; reg state; //sample or hold states reg [5:0] count; //count till 63 starting from 0 reg [7:0] x; //input wire [23:0] sx; //sign extended input reg [23:0] i0; //Integrator output section 0 reg [18:0] i1; //output section 1 under the consideration of Haugenauer's pruning reg [13:0] i2; reg [11:0] i2d1, c1, c0; // Integrator+COMB 0 reg [10:0] c1d1, c2; reg [9:0] c2d1, c3; always @(negedge clk) begin : FSM // finite state machine case (state) hold : begin if (count<63) // setting states for downsampling state <= hold; else state <=sample; end default: state <= hold; endcase end assign sx={{16{x[7]}},x_in}; // Integrator always @(posedge clk)begin if(reset) begin i0 <= 24'd0; i1 <= 19'd0; i2 <= 14'd0; end begin: I x <= x_in; i0 <= i0+sx; i1 <= i1+i0[23:7]; i2 <= i2+i1[18:5]; case (state) //downsample sample : begin c0 <= i2[13:1]; count <= 0; //reset counter once a sample has been fetched end default : count <= count+1; endcase end end // COMB always @(posedge clk) begin: COMB i2d1 <= c0; c1 <= c0-i2d1; c1d1 <= c1[11:1]; c2 <= c1[11:1]-c1d1; c2d1 <= c2[10:1]; c3 <= c2[10:1]-c2d1; end assign y_out=c3[9:2]; endmodule To test it, I wrote the following test bench: `timescale 1ns/1ps module test; reg clk,reset; wire [7:0] x; wire [7:0] y; assign x=8'd0; cicdecim64 cic (x,y,clk,reset); initial begin clk<=1'b0; reset <= 1'b0;# 3 reset=~reset;# 6 reset=~reset; end always# 4 clk=~clk; endmodule However, the simulation in modelsim shows the status of i0 changes to x at the first positive edge of the clock. Can anyone help me solve this problem? Thanks in advanceLink Copied
It could be because the very first value on input x is x so you need to initilise x just like your clock.
Thanks for the reply. x is not the problem since it is defined at the 1st clock edge. However, I tried your suggestion and the result was the same. :/
You should be able to trace the x state from the assignment:
i0 <= i0+sx; and assign sx={{16{x[7]}},x_in}; surely it must be either sx or x_in or x entering x state edit: or i0 first value is x state- Mark as New
I have been struggling in the past 4 days to get this to work and so far it is only getting worse. For instance :
always @(posedge clk)begin if(reset) begin i0 <= 24'd0; i1 <= 19'd0; i2 <= 14'd0; x <= 8'd0; simulation shows only x is becoming 0 when reset is high. The other have the status x from the beginning. Plus modelsim seems to have a problem updating my files from time to time, it kind of stores an older version of each file and uses it, whenever it feels like it. I'm so frustrated right now- Mark as New
I don't remember verilog well but just a thought, you need to insert reset in the sensitivity list as the clock
--- Quote Start --- Body language is essential for an actress, even if you don't use your body in an athletic way. Just to be free, to use it like your voice. A body can be small and have incredible violence. A body talks. --- Quote End --- What the hell? Does this sort of spamming happen often here?
--- Quote Start --- I don't remember verilog well but just a thought, you need to insert reset in the sensitivity list as the clock --- Quote End --- Not really. It is not a must. I never used the reset in the sensitivity list in my old codes and they all worked normally.
Now that I have 5 posts, let me post the code and the simulation properly:
Code:
input clk,reset;
input x_in;
output y_out;
reg count; //count till 63 starting from 0
reg x; //input
wire sx; //sign extended input
reg i0; //Integrator output section 0
reg i1; //output section 1 under the consideration of Haugenauer's pruning
reg i2;
reg i2d1, c1, c0; // Integrator+COMB 0
reg c1d1, c2;
reg c2d1, c3;
case (state)
hold : begin
state <= hold;
else
state <=sample;
end
default:
state <= hold;
endcase
end
assign sx={{16{x}},x_in};
// Integrator
if(reset) begin
i0 <= 24'd0;
i1 <= 19'd0;
i2 <= 14'd0;
x <= 8'd0;
end
else
x <= x_in;
i0 <= i0+sx;
i1 <= i1+i0;
i2 <= i2+i1;
sample : begin
c0 <= i2;
end
default :
count <= count+1;
endcase
end
// COMB
begin: COMB
i2d1 <= c0;
c1 <= c0-i2d1;
c1d1 <= c1;
c2 <= c1-c1d1;
c2d1 <= c2;
c3 <= c2-c2d1;
end
assign y_out=c3;
endmodule
Test bench:
`timescale 1ns/1ps
module test;
reg clk,reset;
reg x;
wire y;
initial begin
x <=8'd1;
clk<=1'b0;
reset <= 1'b0;# 4 reset=~reset;# 5 reset=~reset;
end
always# 4 clk=~clk;
endmodule
Simulation results: http://s10.postimage.org/5g5m5xop5/sim.png As u can see, reset is only resetting x and ignoring the others. http://postimage.org/image/71oahgce5/
I tried the following change and got rid of red undefined states:
i0 <= i0 + {{16{x[7]}},x_in}; //sx;- Mark as New
--- Quote Start --- I tried the following change and got rid of red undefined states: i0 <= i0 + {{16{x[7]}},x_in}; //sx; --- Quote End --- hmm, that did not change anything for me. I simply replaced i0 <= i0 + sx by i0 <= i0 + {{16{x[7]}},x_in} , but the result is still the same.
There are few other changes I made here:
always @(negedge clk) begin : FSM // finite state machine case (state) hold : begin if (count<63) // setting states for downsampling state <= hold; else state <=sample; end default: state <= hold; endcase end assign sx={{16{x[7]}},x_in}; // Integrator always @(posedge clk or reset)begin if(reset) begin count = 6'd0; x = 8'd0; i0 = 24'd0; i1 = 19'd0; i2 = 14'd0; end begin: I x <= x_in; i0 <= i0 + {{16{x[7]}},x_in}; //sx; i1 <= i1+i0[23:7]; i2 <= i2+i1[18:5]; case (state) //downsample sample : begin c0 <= i2[13:1]; count <= 0; //reset counter once a sample has been fetched end default : count <= count+1; endcase end end // COMB always @(posedge clk) begin: COMB i2d1 <= c0; c1 <= c0-i2d1; c1d1 <= c1[11:1]; c2 <= c1[11:1]-c1d1; c2d1 <= c2[10:1]; c3 <= c2[10:1]-c2d1; end assign y_out=c3[9:2]; endmodule- Mark as New
--- Quote Start --- What the hell? Does this sort of spamming happen often here? --- Quote End --- Use the report post button (http://www.alteraforum.com/forum//proweb/buttons/report.gif ) to mark the spam messages as spam and the admins will soon remove it.
Thanks KAZ. It finally worked. Well the results are not right but I can take it from here.
@ dabruk: Thanks. I'll keep that in mind.- Subscribe to RSS Feed
