21615 Discussions
How to use functions in packages on testbench code.
Hi all,
How to use functions in the packages to testbench to give inputs a and b code.
function to_max(a, b : integer) return integer is
variable output :integer;
begin
if (a > b)then
output := a;
return output ;
else
output := b;
return output;
end if;
Thanks in advance
Raghavendra
include it as all other packages. e.g.: use work.my_functions.all
eg:
package my_function is
begin
if (a > b)then
output := a;
return output ;
else
output := b;
return output;
end if;
end package my_functions
library ieee
library work
entity test_program is
port (
x,y : in integer;
y : out integer
architecture beh of test_program is
begin
y =to_max(x,y) ;
end architecture beh;
not synthesizable code but this is just a guide. hope it helps
Thanks..How can i use in testbench code.
--- Quote Start ---
--- Quote End ---
1. Start by reading the two replies that you got to your question when you first posted it.
2. If you're still confused, then ask a question about where you are confused by those two replies
3. Don't ask the same question twice, when it was answered the first time.
KJ
