21604 Discussions
Image Cropping on De2-115 using Verilog
Good Day. I'm currently doing signature verification on DE2-115 using Verilog. I need to compare two different images and I'm having trouble in cropping them. My system needs to crop both my test and genuine signatures which are both initially a 640x480 image. What i know is that i have to determine the rows and columns of the image that are non-zero.My problem now is how would i know the location of the non-zero rows and columns and the maximum value where i would crop it. Also the cropping itself, can I shift them to either right or left or is there another way?
That all depends on what you want to do. Please give us a complete description of your problem, and maybe of your whole system so that we can help you splitting your problem to simple chunks.
How are the images scanned into the system? as a raster scan (top left to bottom right)? If you know the order of the pixels then you should know which row/column you are on.
