Hi, i´m following this example to have ddr3 memory available to the Fabric on the DE0 nano soc.
I write to hps ddr3 with a write master and modular scatter gather DMA. https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/writing_to_hps_memory The first is to tell linux from uboot for reduce their memory usage for example from 1gb to 512mb its trivial. But i don´t undersand how the HPS 2 FPGA SDRAM INTERFACE manages the addresses.For example if it adds some kind of offset. If i write to the address (1 073 741 824 ) / 2 is my data being written just at the beginning of the second 512 mb ram 0X20000000 ? I´m developing some drivers to output linux video to an adv7123 and adv 7511 hdmi and audio to a wm8731 and because the nano doesn´t have ddr on the fabric i will use this approach to use for the buffering stuff.Link Copied
The SD-RAM controller manages addresses (normally) as they are, so if you write to address 0x2000_0000 the data should be at 0x2000_0000...
