21611 Discussions
Leaving target processor paused
I tried to run hello_world project in Nios II, and I got this message. Can anyone help me solve this?
Using cable "USB-Blaster ", device 1, instance 0x00 Processor is already paused Reading System ID at address 0x000000B8: verified Initializing CPU cache (if present) OK Downloading 00200060 ( 0%) Downloaded 4KB in 0.0s Verifying 00200060 ( 0%) Verified OK Leaving target processor paused
Check if Nios reset and exception vectors are placed in a valid memory area.
Also try Debug instead of Run
Check the reset signal
What command are you using? I usually go with nios2-download -g -r file.elf
AAlas3
Check if JTAG UART core is included in Qsys design, if everything is in there try to rebuild the system from scratch (delete the whole project file and build it again), I faced the same problem and tried to rebuild the system again from scratch and it worked.
