21611 Discussions
Cyclone IV vs Cyclone 10 pin compatibility
MGal0
Hi.
I have an old PCB design which uses a Cyclone IV EP4CE6 device in an EQFP package. I would like to know if a cyclone 10 (namely 10CL006 EQFP) would be pin compatible with this PCB. A quick look at the pinout of both devices suggests that the answer is "yes" but I could not find any official statement on the subject. The use of Cyclone 10 will be favorable in terms of cost and power consumption of the chip.
Thanks ahead!
Rahul_S_Intel1
If the pin mapping is found to migrate then it is good to go ( Power pins and IO pins) . And also it is recommended that for upgrading Cyclone IV , the best part is Cyclone 10 LP and if you looking for high performance can go for Cyclone 10 GX
Rahul S
