21611 Discussions
Using differential pins with LVDS capability without buffer
DGugl
Hi, this is most likely a stupidly simple question, i just wanted to know if on max10 devices once can use the differential pins without the deserializers mentioned here
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_lvds.pdf
in general, the question would be whether the differential receivers can be connected directly to the fpga matrix
thanks
Rahul_S_Intel1
From your question, I am interpreting that the IO can be used as LVDS IO standard with out connecting to the LVDS SERDES IP.
>> Yes can be used, you have to change the IO standard to LVDS from the pin planner
