Hi there,
I am looking to buy Stratix EPS1S10F672C6-ES but cannot seem to find the product on the website. Can someone kindly provide a webpage or a link that will be direct me to purchase the mentioned product. Thanks alot in advance.- Tags:
- Intel® Stratix®
That is a part number for an original Stratix series part (circa 2002) EPS1S size 10 package F672 speed grade C6 AND -ES means engineering sample. Nobody is likely going to have -ES versions of these parts anymore.
Mouser has some parts: http://www.mouser.com/productdetail/intel-altera/ep1s10f672c7n/?qs=sgaepimzzmvwljdpjzyitjz6t9dupyh%252btkzq9ufjpok%3d but these are speed grade 7, not 6, for $218 each. It is possible when Altera originally produced the engineering samples (-ES) they tested as grade 6, but when they went into production the yield was mostly grade 7.- Mark as New
Thank you for the quick reply, that does help alot :)
EPS1S10F672C6 or EPS1S10F672C6N will fit your requirement. The -ES versiton just for customer testing or in advance design purpose .
--- Quote Start --- EPS1S10F672C6 or EPS1S10F672C6N will fit your requirement. The -ES versiton just for customer testing or in advance design purpose . --- Quote End --- Unfortunately the faster speed grade (6) is not generally available. You can get them if you want to spring for at least 40pcs @ US$305 each. https://www.buyaltera.com/en/search?kw=ep1s10f672 or http://www.mouser.com/all-manufacturers/_/n-0?keyword=ep1s10f672&fs=true but these will probably be back ordered from Altera and subject to a very long lead time (ie, they have to make the part). Mouser has the C7N in stock at quantity one pricing of US$219 each: http://www.mouser.com/productdetail/altera/ep1s10f672c7n/?qs=p2rvyrazsyg9u0o1b32xcq%3d%3d
Hi All,
Can any one please suggest me the alternate part (pin compatible ) for MFN PN# EP1S10F672C7N and EPM3128ATC100-7N having long lead time? Thanks. Rimpul
Topic Options
