Programmable Devices
20705 Discussions
MAX10 Dual Boot Problem.
EEren
In the bootloader project I create a pof file with two sof files.
The first sof file - the bootloader project, the second one - the main project. At the same time I generate rpd files. From version 16 Quartus generates 2 separate rpd files - for CFM0 and CFM1 sections.
Then I burn the pof file with byte bluster. When I select pin CONGIG_SEL=1 - main runs, when CONGIG_SEL=0 bootloader runs. All good!
Now I burn the generated rpd_cfm1 file serially with the bootloader - and main doesn't run.
So I compared some addresses in SFM1 section - after burning with byte bluster and after burning rpd file - all looks the same. I display only 3 bytes of every word cause I don't have enough 7-segments.
================== ID3 =================
        GOOD        output_file_both_big_cfm1_auto.rpd
ADDRESS
16384   FF E2 FF    FF E2 FF
16385   FF 92 43    FF 92 43
16386   FF 42 DF    FF 42 DF
16387   A8 75 00    A8 75 00
16388   FF FF FF    FF FF FF
16389   FF FF FF    FF FF FF
16390   FF FF FF    FF FF FF
16584   00 00 18    00 00 18
16585   00 00 00    00 00 00
18000   00 05 64    00 05 64
20000   00 00 00    00 00 00
40000   04 40 14    04 40 14
40001   14 C8 82    14 C8 82
40002   96 40 00    96 40 00
40100   42 A1 80    42 A1 80
40400   40 00 00    40 00 00
40800   41 87 8A    41 87 8A
40801   51 76 46    51 76 46
40802   06 65 32    06 65 32
40900   00 00 00    00 00 00
50000   43 12 41    43 12 41
50100   71 18 21    71 18 21
50120   10 00 00    10 00 00
50220   71 12 40    71 12 40
50420   70 11 00    70 11 00
50900   70 75 6D    70 75 6D
114687  FF FF FF    FF FF FF
================== ID4 ================
ALL FF
What is going on?
SreekumarR_G_Intel
can I know when you create the rpd files did you follow as per the max 10 configuration guide steps given in below link page : 39/66
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Is endianess set correct ?
Thank you ,
Sree
EEren
Yes. I set a Big endian option as I was told. Otherwise I have to reverse every byte before writing it to flash. options.png
SreekumarR_G_Intel
Can I know your quartus version ? also can you try below link for the converted rpd file
https://www.intel.la/content/www/xl/es/programmable/support/support-resources/knowledge-base/component/2018/while-loading---cof-file--during-rpd-file-creation--in-quartus--.html
There is issue in the quartus 18.0 and 18.1 version that RPD endianness settling not loading correctly.
Thank you ,
Sree
EEren
My version is 16.0. If I set Little endian - I see the difference while comparing register values - burned with a pof and burned with a rpd.
SreekumarR_G_Intel
sorry i didnt notice your update ; can I know did you get chance to find the issue ?
EEren
The issue remains - when I download the cfm1_auto.rpd serially - the second image doesn't run.
SreekumarR_G_Intel
hmmm...can you send me the design files , let me try it on my side ..
I have one max 10 dev kit ...
EEren
Thanks a lot. I found a bug in my program. Now it's OK.
SreekumarR_G_Intel
ok..thank you :)
Sree
