21602 Discussions
NEEK version of InterNiche Superloop example for 9.0sp1
I have recently posted a NEEK version of this superloop example to the Nios Wiki, please follow the link below.
superloop simple socket server plus (http://www.nioswiki.com/exampledesigns/superloopsimplesocketserverplus) - This is a SUPERLOOP implementation of the Simple Socket Server Plus application. In this example the application is compiled with the InterNiche Stack running in superloop mode, without an RTOS.
Hi, very interesting.
I want to build my own superloop ethernet software for NIOS II. No server yet. Some very basic transferts.
I have a few questions :
Are you obliged to activate the RTOS in system library properties in NIOS II IDE even if RTOS is not used ?
IIRC the IDE prevents you from enabling the Interniche TCP/IP stack without the RTOS. But if you want to run in superloop mode you must disable the RTOS, and the only way to do that with the TCP/IP stack still enabled is to manually edit the system library system.stf file.
Thank you very much. it makes it more understood.
But now I am facing to inclusion problems. I try to "fix".
A lot of tedious work :
Add all new includes paths in project properties (specifically in build properties)
clic, clic, clic, add..., clic, paste, enter, ... reclic, clic, ........:mad:
Do it again for "Debug"
Add Defined SUPERLOOP in Build properties.
....:eek: :confused: :huh: :lol:
