I have a Nios II software application. I was wondering if it is possible, either through configuaration settings in Eclipse, or changing the project Makefile, to have the .elf be built for whichever BSP is selected?
Why not creating two separate projects?
I want to have one code base, so that way, I don't have to keep updating one project and having to update the other one. Also, I want to be able to select which memory map to use at compile time since the software is pretty much the same for both.
After testing out different setups, I came up with the approach of having 'ifeq' statements in the application Makefile, and then having 2 different build configurations in the Eclipse project settings in order to select the location of the BSP files..I think this should work!- Mark as New
Have you tried Project > Properties > Project References?
