20756 Discussions
The ModelSim-Altera can't find MegaCore libraries
Hi.
I try to simulate my design in ModelSim-Altera. My design includes FIFOs produced by Quartus MegaCore.
So, I have troubles with the FIFO simulation.
In Altera support I found that "ModelSim-Altera edition and ModelSim-Altera Web Edition come with pre-compiled Altera libraries". Anyway, I try to compile the altera_mf library.
I get error:
# ** Error: (vcom-19) Failed to access library 'work' at "d:/quartus_72sp2/quartus/tpi/mgc_oem/libs/altera/vhdl/altera_mf".
The Quatrus software installed in other directory than ModelSim lookong for.
Where can I change the path for the libraries?
As you mentioned, ModelSim Altera comes with precompiled libraries. Hence, you don't need to compile altera_mf library.
Also, all the needed files are under ModelSim folder, you don't even need Quartus installed on the same computer to do simulations.
