21615 Discussions
Understand and solve setup violation in dual domain clock
Hello all,
I have a project where I have two clock:
- 50 MHz oscillator for NIOS synthetized on FPGA
- 60 MHz oscillator for USB (from UM232H module) used in a custom component attached wtih QSys to NIOS
QSys automatically handle cross-domain transfers of signals.
I wat to see signals that come and go into USB module with signaltap so I have multiplied by 2 (to 120 MHz) USB clock with a PLL and attached it to SignalTap.
Timing requirements are not met because I have ADBUS signals (bidirectional DATA signals for USB) that violate setup timing by -0.684ns
If I report Timing Closure Reccomendations with TimeQuest I get:
--- Quote Start ---
Register the partition boundaries for the path from pin_ft232h_ADBUS[5] to sld_signaltap:aut...rigger_in_reg[5]
Issue: Cross-partition Paths
To: sld_signaltap:auto_signaltap_0|acq_trigger_in_reg[5]
TimeQuest analysis: report timing
Partitions that should be merged:
Top -> sld_signaltap:auto_signaltap_0
--- Quote End ---
What can I do? Attached Timequest details
Deleting ADBUS from signaltap seem to remove violation. Are so hard to observe bidirectional pin?
