20736 Discussions
Using JTAG as General I/O
I'm using a MAX 7000S EPM7064S and need the JTAG pins to be used as general I/O pins once the device has been programmed. Does anyone have any ideas?
Hello dth21,
Sorry but JTAG programming pins are dedicated IO and can not be used as general purpose I/O (I believe this is true for all families).
Chris
The following link may help you but only if you have not programmed the device via ISP(In System Programming)
http://www.altera.com/support/kdb/solutions/1415.html
Thanks, wizard...
"The force is strong with this one... "
Apologies for the erroneous advice, dth21
skids
BTW: The tcl to allow JTAG pins for user IO is:
set_global_assignment -name MAX7000_ENABLE_JTAG_BST_SUPPORT OFF
