Programmable Devices
20803 Discussions
VHDL problem?
QUESTION:
Develop a VHDL model for an accumulator that calculates the sum of a sequence of fixed-point numbers.
Each input number is signed with 4 pre-binary-point and 12 post-binary-point bits.
The accumulated sum has 8 pre-binary-point and 12 post-binary-point bits.
A new number arrives at the input during a clock cycle when the data_en control input is 1.
The accumulated sum is cleared to 0 when the reset control input is 1.
Both control inputs are synchronous.
DOUBT:
I want to ask how to insert the first input and second input as it using the pre and post numbers?
How to store the value for the first input for awhile before it add the second input?
The output will light up using LED at the board that we assign it by ourselves.
library ieee;
use ieee.std_logic_1164.all, ieee.numeric_std.all;
entity accumulator is
port (clk,reset, data_en : in std_logic;
data_in : in signed(15 downto 0);
data_out : out signed(19 downto 0) );
end entity accumulator;
architecture rtl of accumulator is
signal sum, new_sum :signed(19 downto 0);
begin
new_sum <= sum + resize(data_in, sum'length);
reg:process (clk) is
begin
if rising_edge(clk) then
if reset = '1' then
sum <= (others => '0');
elsif data_en = '1' then
sum <= new_sum;
end if;
end if;
end process reg;
data_out <= sum;
end architecture rtl;
-KYRA-:)
i dont understand your questions. The code you posted does what the question asks.
for store the value for the first input for a while before it add the second input, is stored in a register
i wanna ask how to store value in register and synchronize it with usb blaster?what is the code to be use in the programing?i search through the internet but can't understand it..hope anybody can help asap,,,
--- Quote Start ---
--- Quote End ---
It will be stored in sum. It wont change until the next data value arrives
based on code above,there is up until 20-bits,but on the DE2 usb blaster board,there is only enough for up until 10-bits.can i know how to re-make the code so it will synchronize with the pins available on the board?
--- Quote Start ---
--- Quote End ---
You can do this by passing first 10 bits during clock high and another 10 bits during clock low.
--- Quote Start ---
--- Quote End ---
can i know what is the suitable code to do the passing bits process?
Suppose u r gonna pass out A (4 bits), define another vector for example B (2 bits),
if clock'event and clock='1' then
B(0) <= A(0);
B(1) <= A(1);
end if;
if clock'event and clock='0' then
B(0) <= A(2);
B(1) <= A(3);
end if;
--- Quote Start ---
B(0) <= A(0);
B(1) <= A(1);
end if;
B(0) <= A(2);
B(1) <= A(3);
end if;
--- Quote End ---
B is your real output
--- Quote Start ---
--- Quote End ---
--this is my code but there are errors..
--the errors are
Error (10344): VHDL expression error at acc.vhd(97): expression has 16 elements, but must have 20 elements
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings
Error: Peak virtual memory: 183 megabytes
Error: Processing ended: Wed Mar 30 08:42:58 2011
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 4 errors, 2 warnings
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity acc is
port (
a: in signed (15 downto 0);
b: in signed (15 downto 0);
clk: in std_logic;
ena: in std_logic;
rst: in std_logic;
q: out signed (19 downto 0)
end acc;
architecture rtl of acc is
signal a_reg, b_reg: signed (15 downto 0);
signal q_reg1, q_reg2: signed (15 downto 0);
signal acc_out: signed (19 downto 0);
begin
process (clk, rst)
begin
if (rst = '1') then
a_reg <= (others => '0');
b_reg <= (others => '0');
q <= (others => '0');
elsif (clk'event and clk = '1') then
a_reg(0) <= a(0);
a_reg(1) <= a(1);
a_reg(2) <= a(2);
a_reg(3) <= a(3);
a_reg(4) <= a(4);
a_reg(5) <= a(5);
a_reg(6) <= a(6);
a_reg(7) <= a(7);
if (clk'event and clk = '0') then
a_reg(8) <= a(8);
a_reg(9) <= a(9);
a_reg(10) <= a(10);
a_reg(11) <= a(11);
a_reg(12) <= a(12);
a_reg(13) <= a(13);
a_reg(14) <= a(14);
a_reg(15) <= a(15);
q_reg1 <= a_reg;
end if;
end if;
end process;
process (ena)
begin
if (ena = '1') then
b_reg(0) <= b(0);
b_reg(1) <= b(1);
b_reg(2) <= b(2);
b_reg(3) <= b(3);
b_reg(4) <= b(4);
b_reg(5) <= b(5);
b_reg(6) <= b(6);
b_reg(7) <= b(7);
end if;
b_reg(8) <= b(8);
b_reg(9) <= b(9);
b_reg(10) <= b(10);
b_reg(11) <= b(11);
b_reg(12) <= b(12);
b_reg(13) <= b(13);
b_reg(14) <= b(14);
b_reg(15) <= b(15);
q_reg2 <= b_reg;
end if;
acc_out <= q_reg1 + q_reg2;
end if;
end process;
q <= acc_out;
end rtl;
--can anybody make it correct??
--- Quote Start ---
--the errors are
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity acc is port ( a: in signed (15 downto 0); b: in signed (15 downto 0); clk: in std_logic; ena: in std_logic; rst: in std_logic; q: out signed (19 downto 0) ) ; end acc; architecture rtl of acc is signal a_reg, b_reg: signed (15 downto 0); signal q_reg1, q_reg2: signed (15 downto 0); signal acc_out: signed (19 downto 0); begin process (clk, rst) begin if (rst = '1') then a_reg <= (others => '0'); b_reg <= (others => '0'); q <= (others => '0'); elsif (clk'event and clk = '1') then a_reg(0) <= a(0); a_reg(1) <= a(1); a_reg(2) <= a(2); a_reg(3) <= a(3); a_reg(4) <= a(4); a_reg(5) <= a(5); a_reg(6) <= a(6); a_reg(7) <= a(7); if (clk'event and clk = '0') then a_reg(8) <= a(8); a_reg(9) <= a(9); a_reg(10) <= a(10); a_reg(11) <= a(11); a_reg(12) <= a(12); a_reg(13) <= a(13); a_reg(14) <= a(14); a_reg(15) <= a(15); q_reg1 <= a_reg; end if; end if; end process; process (ena) begin if (ena = '1') then if (clk'event and clk = '1') then b_reg(0) <= b(0); b_reg(1) <= b(1); b_reg(2) <= b(2); b_reg(3) <= b(3); b_reg(4) <= b(4); b_reg(5) <= b(5); b_reg(6) <= b(6); b_reg(7) <= b(7); end if; if (clk'event and clk = '0') then b_reg(8) <= b(8); b_reg(9) <= b(9); b_reg(10) <= b(10); b_reg(11) <= b(11); b_reg(12) <= b(12); b_reg(13) <= b(13); b_reg(14) <= b(14); b_reg(15) <= b(15); q_reg2 <= b_reg; end if; acc_out <= q_reg1 + q_reg2; end if; end process; q <= acc_out; end rtl;
--is this code suitable for board DE1?
The problem on this lineacc_out <= q_reg1 + q_reg2;is that acc_out is 20 bits and q_reg1 and q_reg2 are 16 bits. The result of the addition is 16 bits and it won't be resized automatically to 20 bits for you. Try something like that instead:
acc_out <= resize(q_reg1,20) + resize(q_reg2,20);It is better to increase the size before performing the addition in case you need the 17th bit in the result and prevent an overflow.
And by the way, b_reg(8) <= b(8); b_reg(9) <= b(9); b_reg(10) <= b(10); b_reg(11) <= b(11); b_reg(12) <= b(12); b_reg(13) <= b(13); b_reg(14) <= b(14); b_reg(15) <= b(15);can be replaced by b_reg(15 downto 8) <= b(15 downto 8);
I have never seen two nested clock edge statements...has vhdl standards changed?
--- Quote Start ---
--- Quote End ---
Ill open a book on how long before he comes back asking why his code wont compile!
--- Quote Start ---
--- Quote End ---
The nested clock edge condidtion compiles, because it's legal VHDL syntax. But the respective part will be ignored similar to a block under an if false then condition.
I'll remember it for interview questions.
I think when it comes to synthesis we better stick to the proven predictable templates rather than the legality of code. Tools don't always respect the legalities as they are made by low paid software people.
Moreover, the above code will lose the intention as the second edge statement overwrites the first edge.
I believe the intention is DDR, so you can use DDR function or your own.
The code is very unsynthesisable. The second clock edge is looking for falling edge, and because its inside the rising edge if branch, its basically looking for a rising and falling edge at the same time (so as well as looking for both edges which is impossible in an FPGA, it looks for them simultaneously).
