Programmable Devices
20735 Discussions
Virtual JTAG: "Hub IP" register value?
Hello.
According to the virtual JTAG Megafunction guide the "Hub IP configuration register" contains the following values:
Bits 7-0: SUM(m,n)
Bits 18-8: ALTERA_MFG_ID = 0×6E
Bits 26-19: N
Bits 31-27: version
However in my tests (using Quartus II 11.0 and the Cyclone II evaluation board) Bits 7-0 seem to contain the number "m" only, not "m+n".
In the current project the virtual IR register (User1) is 13 bytes long (n=3, m=10) and bits 7-0 of the configuration register contain the number 10, not 13 as expected. I also tried (n=1, m=4) and (n=1, m=5); the configuration register values were 4 and 5, not 5 and 6 as expected.
Is this
- A bug in the virtual JTAG Hub or
- a bug in the documentation or
- do I do anything wrong??
Martin
--- Quote Start ---
--- Quote End ---
The documentation is wrong. Here's my analysis
http://www.ovro.caltech.edu/~dwh/correlator/pdf/vjtag.pdf
Cheers,
Dave
Hey Dave,
I have been struggling issuing the VIR HUB_INFO instruction and then shifting out the resulting data. How to target the SLD_hub in that case?
--- Quote Start ---
--- Quote End ---
Download the zip file for this tutorial:
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial
There's a Tcl script in there for use with Quartus stp. It has all the hub interrogation code, eg., print_hub_info and print_node_info. Read that code, it'll show you how it all works.
Cheers,
Dave
Hats off to you Sir, That bit of information was what I was missing in my logic
--- Quote Start ---
--- Quote End ---
You're welcome!
Cheers,
Dave
