21602 Discussions
Waveform simulation no results!
VHDL code is not wrong ,but when i create do not get the results of simulation waveform file.somewhere i malke a mistake !! can you help me ?
library ieee;
use ieee.std_logic_1164.all;
entity counter10 is
port (clk: in std_logic;
digit : out std_logic );
end counter10 ;
architecture counter10 of counter10 is
begin
process (clk)
variable temp:integer range 0 to 10;
begin
if(clk'EVENT AND clk='1')then
temp:= temp+1;
if (temp=10)then temp:=0;
end if ;
end if ;
end process;
end counter10 ;
Do you assign any value to the output port digit?
no , i thinlk it's output port .need assign value ?o i try it again . than you !
