21611 Discussions
Writing integer value out to LCD on DE2 board
I'm using the university program 16x2 character display component in SOPC builder and i can write text to the LCD via a C program in NIOS II no problem. eg ...
alt_up_character_lcd_string(char_lcd_dev, "Hello Altera Forum!");
But, i have a 7 bit PIO value defined as# define switches (volatile char*) 0x00101060
How can i display this on the LCD ? i know how to do it with standard C and printf but not this.
I have looked through the document for this component and there is another function called alt_up_character_lcd_write but it doesn't give an example of it should be used
Why not format a string first?
char str[80];
int data;
data = <read from the LED>
sprintf(str, "LED value is 0x%X", data);
alt_up_character_lcd_string(char_lcd_dev, str);
Cheers,
Dave
--- Quote Start ---
char str[80];
int data;
Cheers,
Dave
--- Quote End ---
Dave you're a hero. I didn't think i could do it like that. Works a charm
Thankyou
Great!
Cheers,
Dave
