- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
I am trying to program an apollo agilex board.
In doing so I have the problem of setting the VID assigments of the card.
(I could not find any documentation from terasic on the correct VID settings so I had to find them in examples projects, so I am not a 100% sure they are right)
so here are my settings :
set_global_assignment -name USE_PWRMGT_SDA "SDM_IO0"
set_global_assignment -name USE_PWRMGT_SCL "SDM_IO12"
set_global_assignment -name PWRMGT_SLAVE_DEVICE_TYPE "Other"
set_global_assignment -name PWRMGT_SLAVE_DEVICE0_ADDRESS "4F"
set_global_assignment -name VID_OPERATION_MODE "PMBUS MASTER"
set_global_assignment -name PWRMGT_BUS_SPEED_MODE "400 KHZ"
set_global_assignment -name PWRMGT_VOLTAGE_OUTPUT_FORMAT "LINEAR FORMAT"
set_global_assignment -name PWRMGT_LINEAR_FORMAT_N "-12"
set_global_assignment -name PWRMGT_TRANSLATED_VOLTAGE_VALUE_UNIT "VOLTS"
set_global_assignment -name PWRMGT_PAGE_COMMAND_ENABLE "ON"
set_global_assignment -name PWRMGT_PAGE_COMMAND_PAYLOAD "255"
they all seem to be legal, but running my quartus synthesys I get these errors :
quartus_syn integnano_pinaipple_pinaipple_system_0
Error (22819): The option assigned for assignment (USE_PWRMGT_SDA : SDM_IO0) is not supported.
Error (22819): The option assigned for assignment (USE_PWRMGT_SCL : SDM_IO12) is not supported.
This is weird to me since I am running quartus prime pro 22.4.0 (which is not that old) and the configuration page for agilex says thoses SDA and SCL configs are allowed :
I will try installing quartus 23.1 to solve this issue.
Is there something I am doing wrong here ?
Many thanks
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi there,
Your setting of "SCL" and "SDA" seems be reversed. SCL for IO0 and SDA for IO12~
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi there,
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi there,
Is it solved~
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I was indeed too tired to notice ^^'
sorry for the useless thread and thanks you for the response.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
