first, i used the Cyclone, my program ran correctly.
then, i changed it to Cyclone IV, then the error occurs. some controlling order in my program is wrong, i have not changed my program. so , what's the matter? someone can help me?Link Copied
what error?
of course. Cyclone (I) and Cyclone IV are different devices (obviously).
--- Quote Start --- what error? --- Quote End --- My program control different periphery devices, such as valves, stepmotors. when i changed my FPGA, the control signals are not correct, so these periphery devices can't work Normally.
--- Quote Start --- of course. Cyclone (I) and Cyclone IV are different devices (obviously). --- Quote End --- i konw, but i changed the setup(device) in Quartus. So, the program should ran correctly.(i have tested an easy demo, and it run correctly in Cyclone IV)
when you changed the device, there should be a warning saying that your pin assignments will be gone.
Yes, the first thing I would check is the pin assignments.
--- Quote Start --- when you changed the device, there should be a warning saying that your pin assignments will be gone. --- Quote End --- i changed, of course. the problem is solved!!! i changed my program in some details. the error occurs in one of a state machines, but i can't talk it more detailed because of keeping secrets for my boss. i still don't know there are differences when the same program runs in different FPGAs. can you give me some advice?
--- Quote Start --- Yes, the first thing I would check is the pin assignments. --- Quote End --- i changed, of course. the problem is solved!!! i changed my program in some details. the error occurs in one of a state machines, but i can't talk it more detailed because of keeping secrets for my boss. i still don't know there are differences when the same program runs in different FPGAs. can you give me some advice?
From Cyclone to Cyclone IV there are differences in the PLLs, the memory components, some I/O features, timing and of course the pins. All of those can cause errors.
