21611 Discussions
ethernetconnection
Hey I want to connect my DE2 board with my pc via Ethernet to transmit Data from the FPGA. What is the easiest way to implement this and how i do this?
Kind Regards
Nios. LwIP.
Rated from easiest to hardest:
(1) Nios II, UDP data transmission (see DE2_NET example provided by Terrasic)
(2) Nichestack TCP/IP stack and Altera socket-reference designs.
For a recently released *working* solution using TCP/IP which uses the latest Altera-provided reference design, see my post here:
http://www.alteraforum.com/forum/showthread.php?p=95360
