I have a simple process in a max 2 that writes and is supposed to read a register array and put the data onto device pins- the same pins I use to write data to the register.
It is really simple: register_process: process(localclk, reset_pulse, reset_flash, Dcsn) begin if localclk'event and localclk = '1' then if Dwrn = '0' and Dcsn = '0' and Drdn = '1' then case Daddr(3 downto 0) is when "0000" => reg0 <= Data(2 downto 0); when "0010" => reg2(7 downto 0) <= Data(7 downto 0); when "0011" => reg2(15 downto 8) <= Data(7 downto 0); when "0100" => reg2(23 downto 16) <= Data(7 downto 0); when "0101" => reg3 <= Data(7 downto 0); when "0110" => reg4 <= Data(7 downto 0); when "0111" => reg5(7 downto 0) <= Data(7 downto 0); when "1000" => reg5(15 downto 8) <= Data(7 downto 0); when "1001" => reg5(23 downto 16) <= Data(7 downto 0); flash_load <= '1'; when "1010" => reg6(7 downto 0) <= Data(7 downto 0); when "1011" => reg6(15 downto 8) <= Data(7 downto 0); when "1100" => reg6(23 downto 16) <= Data(7 downto 0); pulse_flag <= '1'; when others => null; end case; elsif Drdn = '0' and Dcsn = '0' and Dwrn = '1' then case Daddr(3 downto 0) is when "0000" => Data(2 downto 0) <= reg0; when "0001" => Data(7 downto 0) <= quad_count; quad_reset <= '1'; when "0010" => Data <= reg2(7 downto 0); when "0011" => Data <= reg2(15 downto 8); when "0100" => Data <= reg2(23 downto 16); when "1101" => Data <= keys(7 downto 0); when "1110" => Data(2 downto 0) <= keys(10 downto 8); when others => null; end case; elsif reset_pulse = '1' then reg6 <= "000000000000000000000000"; elsif reset_flash = '1' then flash_load <= '0'; else Data <= "ZZZZZZZZ"; quad_reset <= '0'; end if; end if; end process register_process; The problem is that data is correctly written and I can see it on the Q pins of the ffs but I can't seem to get it back on the device pins. I know I am forgetting something and I hope someone will just put me out of my misery and tell me what it is. Thank you,Link Copied
You can use an interim signal set and then gate that set onto the pins external to the process:
Register_Process: Process(Localclk, Reset_Pulse, Reset_Flash, Dcsn) Begin If Localclk'Event And Localclk = '1' Then If Dwrn = '0' And Dcsn = '0' And Drdn = '1' Then Case Daddr(3 Downto 0) Is When "0000" => Reg0 <= Data(2 Downto 0); When "0010" => Reg2(7 Downto 0) <= Data(7 Downto 0); When "0011" => Reg2(15 Downto 8) <= Data(7 Downto 0); When "0100" => Reg2(23 Downto 16) <= Data(7 Downto 0); When "0101" => Reg3 <= Data(7 Downto 0); When "0110" => Reg4 <= Data(7 Downto 0); When "0111" => Reg5(7 Downto 0) <= Data(7 Downto 0); When "1000" => Reg5(15 Downto 8) <= Data(7 Downto 0); When "1001" => Reg5(23 Downto 16) <= Data(7 Downto 0); Flash_Load <= '1'; When "1010" => Reg6(7 Downto 0) <= Data(7 Downto 0); When "1011" => Reg6(15 Downto 8) <= Data(7 Downto 0); When "1100" => Reg6(23 Downto 16) <= Data(7 Downto 0); Pulse_Flag <= '1'; When Others => Null; End Case; Elsif Drdn = '0' And Dcsn = '0' And Dwrn = '1' Then Case Daddr(3 Downto 0) Is When "0000" => Outputsig(2 Downto 0) <= Reg0; When "0001" => Outputsig(7 Downto 0) <= Quad_Count; Quad_Reset <= '1'; When "0010" => Outputsig <= Reg2(7 Downto 0); When "0011" => Outputsig <= Reg2(15 Downto 8); When "0100" => Outputsig <= Reg2(23 Downto 16); When "1101" => Outputsig <= Keys(7 Downto 0); When "1110" => Outputsig(2 Downto 0) <= Keys(10 Downto 8); When Others => Outputsig <= "Xxxxxxxx"; End Case; Elsif Reset_Pulse = '1' Then Reg6 <= "000000000000000000000000"; Elsif Reset_Flash = '1' Then Flash_Load <= '0'; Else Data <= "Zzzzzzzz"; Quad_Reset <= '0'; End If; End If; End Process Register_Process; Outen <= Not Drdn And Not Dcsn And Dwrn; Data <= Outputsig When Outen = '1' Else "Zzzzzzzz";
