Hi all!
I'm working with Cyclone V, my aim is to use DDR memory. Am I right that I need to create my own controller and use ALTDQ_DQS2 IP Core as PHY? I mean that Altera removed support of DDR memory controller in Cyclone V.Link Copied
Correct, Altera DDR controller is not supported on Cyclone V.
If this is a new design, my suggestion would be to use Cyclone V with Hard Memory Controller and select a compatible memory device.- Mark as New
Thanks for your answer, ted.
No, design hasn't the ability to use HMC. I think that I have to use ALTDQ_DQS2 and custom VHDL_or_Verilog Controller
