20789 Discussions
matlab to verilog converter request
Hi there,
Is there a compiler which can convert Matlab code directly in to VHDL/verilog format so to implement the code directly in to FPGA? I have written codes on MATLAB and would like to convert the code in to verilog format so to make my life easier.:)
me w8ting for your response!!!!
thnks
--- Quote Start ---
Hi there,
thnks
--- Quote End ---
Did you try the MATLAB site?
http://www.mathworks.com/products/slhdlcoder/index.html
http://www.mathworks.com/products/filterhdl/
These converters are for very specific logic implementations.
There will not be a general-purpose m-file to HDL converter.
If you want an optimal hardware implementation, you are better off writing HDL, and using the MATLAB model for comparison testing.
Cheers,
Dave
HDL coder is more a simulink tool and only a subset of embeded m can be converted.
Almost any higher level language to verilog/vhdl conversion will not give you optimal results, except for very basic implementations. The problem is the C/Matlab/ etc. languages do not have hardware constructs, so the conversion is forced to basically generate a flat unrolled design that ends up taking more resources and running slower than the desired operation.
In one case I worked on, a software engineer tried to use a C->Verilog converter to generate code for image warping. The C code worked, but was too slow. (Taking several seconds to warp a signal 800x480 frame). She worked with an FAE for over 4 months trying to convert the algorithm to a hardware implementation. The net result was they could never get it to fit in the target device.
I took the software and was able to generate a pretty small design that could do the warping at 20->30 pfs. (with 15 fps being the target update rate).
matlab code converted to VHDL? sound interesting. :)
Altera's DSP Builder Advanced blockset for Simulink should be mentioned here. it doesn't convert M code, but the HDL it outputs is generally very efficient
u thnx a lot...
also i want to guide me in my project which is ''fpga imlementation of linear discriminant analysis for p300 signal detection''...
plz guide me
u thnx a lot...
plz guide me...
