Is it possible to define multiple code (.text) sections within an object file?
For instance: [ text ] [ text_a ] [ text_b ] [ text_c ] Where 'text' contains the actual code for the object file. text_a will refer to/get loaded with code from another object file ........... and so on. How can I achieve this? I'm using NIOS II IDE version 8Link Copied
