21611 Discussions
need help in correcting errors in fifo verilog
Can u help me debug errors in the fifo code?
I am trying to find error but I have not suceeded in finding any.
module newfifo(rst,
clk,
din,
wr_in, //write_enable signal
rd_in, // read_enable
dout, //data_out
empty,//data_in
full);
input rst,
clk;
input [7:0]din;
input wr_in,rd_in;
output [7:0]dout;
output empty,full;
reg [7:0] dout;
reg [3:0]read_ptr, write_ptr; //read and write pointers
reg [7:0] mem [14:0];
always@(posedge clk or negedge rst)
begin
if (rst)
write_ptr<=0;
else if (wr_in==1)
begin
mem[write_ptr[3:0]]<=din;
write_ptr <= write_ptr+1;
end
end
begin
if (rst)
begin
read_ptr<=0;
dout<=0;
end
else if (rd_in==1)
begin
dout<=mem[read_ptr[3:0]];
read_ptr <= read_ptr+1;
end
end
endmodule
//testbench
`timescale 1ns / 1ps
module newfifotestbench();
reg rst;
reg clk;
reg [7:0] din;
reg wr_in;
reg rd_in;
wire [7:0] dout;
wire empty;
wire full;
newfifo h1 (.rst(rst),
.clk(clk),
.din(din),
.wr_in(wr_in),
.rd_in(rd_in),
.dout(dout),
.empty(empty),
.full(full));
initial begin
$shm_open("newfifo.shm");
$shm_probe(clk);
$shm_probe(rst,din,dout,wr_in,rd_in,full,empty);
end*/
integer i;
always# 10 clk=~clk;
initial
begin
clk=0;
rst=0;
# 100 rst=1;
wr_in=1;
rd_in=0;
for(i=0;i<5;i=i+1)
begin
# 20 din[7:0]=8'b10101010;
# 20 din[7:0]=8'b11001100;
# 20 din[7:0]=8'b11111111;
end
wr_in=0;
rd_in=1;
# 1000;
end
endmodule
The problems that I am facing are:
dout signal always stays at 0000000 inspite of my read_en going high.
Secondly, can u give me tips on how to write statement for empty and full.
Kindly excuse me if there are any mistakes as I am a beginner.
Thanks in advance.
As I am not able to post my siumlation output as an attachment,as I do not have 5 posts till now, kindly visit this link h**p://images.elektroda.net/92_1306588874.png for the simulation image.
Check the sense of your reset.
I am sorry, I have not understood. do i need to check reset in my program? (reset is an asynchronous active low signal in my case.) can u explain in a slightly detailed manner?
Your code is active on low reset but your testbench raises reset so your design stays under reset. You need to release the reset by lowering it to '0'
oops!! i just understood the mistake now..thanks a lot!! but now,i realise that there are a few errors like immediately after my data_in is over, for a certain period of time although my rd_in is high, i don get dout immediately. its like there is an xxxxxxx state for one clock pulse before my dout starts. can u give me some tips on how to change so that i get my dout immediately after my din stops?
you will get one clock delay from address sampling point at least since sampling is at clock edge e.g. when address = 0 then it is read as zero at incoming clock edge and data0 becomes available at next clock edge.
With regards to x states this is trivial, you can just initilise your array mem but is not essential.
