20764 Discussions
output to header on DE0-nano cyclone IV E
DE0-nano FPGA identifies header output as example GPIO_2 header JP1 as Pin 5.
I have used the DE0-nano FPGA system generator to set the project.
I used the .bdf file system to create the code.
How do I get the signal to an output pin. I get a ripple type signal.
The difference between the max and Min is only 150 MV where the Max is 3.3 and the Min is 3.15
I think I ask the wrong question.
The DE0-Nano board user manual shows Header JP1 PIN 5 is GPIO_02.
How is this equated to chip pin in the pin planner.
If you have a look at the board schematics you should see which FPGA pin the CPIO_02 signal is connected to.
The pin assignments are also in the user manual.
Some time in the past I had used the back annotation and it was wrong.
Don't use the back annotator. Had to remove all assignments and reassign.
Wrong you must use the back annotation.
