Hi everyone,
I have a problem due to the type of identifier "clock" as I declare as a bit type. Below is my short code: ---------------------------------------------------------------------------------------------- Package my_main_data is Type main_vector is array (7 downto 0) of integer; End my_main_data; LIBRARY ieee; USE ieee.ALL; Use work.my_main_data.all; Use work.my_data_types.all; ENTITY case IS PORT ( clock : IN bit; Ip : IN main_vector; Op : OUT main_vector ); END case; ARCHITECTURE case OF case IS COMPONENT cone PORT ( I: IN vector; clk: IN bit; O: OUT vector ); END COMPONENT; SIGNAL out_r1, out_r2: vector; SIGNAL clk : bit; BEGIN R1: cone PORT MAP (Ip(0), clock, out_r1(0); PORT MAP (Ip(1), clock, out_r2(0); End case; ------------------------------------------------------------------------------------------------ This error occur when I compile the code: Error (10476): VHDL error at haar.vhd(62): type of identifier "clock" does not agree with its usage as "integer" type Can anyone tell me where is my mistake..http://www.edaboard.com/images/smilies/icon_sad.gif Many thanksLink Copied
I dont beleive this is the same code you're trying to compile.
And where is the definition of the "vector" type?- Mark as New
I'm not aware of a legal VHDL syntax with multiple port maps in a single component instantiation.
