Programmable Devices
20750 Discussions
waiting for clock ?!
Hello, I am using signal-tap to investigate a problem.
But currently the problem is signalTap itself.
I have a trigger clock (100 Mhz), which I am sure its running, otherwise
nothing would run on the FPGA but a PC, which is connected to that FPGA board is receiving the data..this means that the clock must run
The strange thing is that Signal-Tap displays that he is waiting for the clock.
So this means that S.T. doesnt see any clock transitionon the trigger clock
I am only using signals from the presynthesis
Does anybody else here has already encountered the same kind of problem ?
Could it be a JTAG connection problem ? But flashing the FPGA is working fine
and S.T. doesn't report any bad JTAG connection
--- Quote Start ---
--- Quote End ---
did you get any warning during compilation that your clock node isn't found ?
When you open the stp-file is the clock node dispalyed in red colour ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
no they're displayed in black and I dont see any warning.
this is a really strange behaviour.
I have used S.T. really often in the past, but this is also new for me
--- Quote Start ---
--- Quote End ---
I only run into this problem when the selected node was removed or renamed by Quartus,
but then the node was dispalyed in red colour. Did you change the Quartus version ?
Kind regards
GPK
If I remember right, the only reason why I get this message was a clock, that has been actually stopped.
I solved the problem when I use post-fitting signals instead of pre-synthesis signals. Hmm strange..formerly it was always working with pre-synthesis signals
