I accidentally enabled RST and XMP at the same time on a perfectly working new build and it has corrupted the m.2 boot drive. I9 proccessor with ASUS p790 motherboard.
Drive still works, drive bay still works. but the drive will not bring up windows, crashes.
Started new build up with alt boot disk, so it is good.
Hello pslavich,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with the Intel® Rapid Storage Technology (Intel® RST).
1. Just to confirm, by "Started new build up with alt boot disk" does that mean that you are using a new SSD or that reinstalled the operating system in the current SSD?
2. Do you need further support? Can you provide more details about your issue?
3. Did you set a RAID configuration? If so, which RAID configuration are you using?
Deivid A.
Hello pslavich,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hello pslavich,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
