Rapid Storage Technology
Intel® RST, RAID
2209 Discussions
C602 Clipset RAID 5 Write speed is too looooooow!!!
LeonLin
i need help to fix this problem!
LeonLin
Is there any setting in the BIOS that is not turned on?
AlHill
Whose bios?
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
AndrewG_Intel
Hello @LeonLin
We are checking this thread and we would like to know if you were able to run the Intel® System Support Utility for Windows* (Intel® SSU)?
Or could you please confirm the full/exact model of your system regarding this inquiry?
Also, please confirm if this is regarding the "regular" Intel® Rapid Storage Technology (Intel® RST), or if this is regarding Intel® Rapid Storage Technology enterprise (Intel® RSTe).
Andrew G.
AndrewG_Intel
Hello LeonLin
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
