Rapid Storage Technology
Intel® RST, RAID
2248 Discussions
Dynamic Storage Accelerator setting disappeared from RST software on Windows 10 x64 10586.164
DPokr1
For some reason Dynamic Storage Accelerator setting has gone from RST software 14.8.0.1042 on Windows 10 x64 10586.164. It was definitely there before 10586.122.
i7-4770 + Z97 + DSA enabled in BIOS.
Could anyone else confirm this, please?
Allan_J_Intel1
Do you have that option with previous Intel® Rapid Storage software versions?
https://downloadcenter.intel.com/product/55005/Intel-Rapid-Storage-Technology-Intel-RST- Drivers & Software
Allan.
DPokr1
Just to be sure I have reverted RST back to vendor's 14.5.0.1081 (driver and software) and even re-flashed BIOS, but with no luck. I'm pretty sure it was there before either with 14.8.0.1042 or 14.5.0.1081 or both (I got screenshot), but not anymore after 122 and 164 updates.
Allan_J_Intel1
It appears to be an issue after windows update. You may need to run system restore to go back to an earlier date or wait for future Intel® Rapid Storage software releases.
Allan.
DPokr1
Ok, thanks. I'd better to wait either for a new RST release or further Windows updates - one that would fix that first.
Allan_J_Intel1
Sure, no problem. Please keep on checking https://downloadcenter.intel.com/default.aspx Drivers & Software for any driver update.
Allan.
BPAVO
Or Try my solution when you waiting for new driver :
Good day to you
DPokr1
Thank you for the advice. In my case I found that for some reason Windows/RST has stopped correctly working with C-states. Once I switched the CPU C-states option in BIOS from "Auto" to "Enabled", Dynamic Storage Accelerator magically began working once again. It was definitely something between BIOS, Windows and RST after their updates.
