Rapid Storage Technology
Intel® RST, RAID
2245 Discussions
Extracting drivers from the RST installer
ritmo2k
It seems none of the options for extracting the drivers are valid anymore.
I have downloaded the installer from https://www.intel.com/content/www/us/en/download/19512/intel-rapid-storage-technology-driver-installation-software-with-intel-optane-memory-10th-and-11th-gen-platforms.html and tried the following:
SetupRST.exe -extract <path>
SetupRST.exe -a -p <path>
But neither works. Does anyone know how to do it with the most recent version, or if an F6 floppy archive still exists?
Thanks!
Serag
These are the file i guess you’re trying to find hopefully you will download them before they get taking off good luck
Kaspo11
Serag is a lifesaver....I couldn't get to the install/extract option of this file because it wouldn't even let me in because it said unsupported platform....I created an account just to say thank you, I was clueless.
Gyanesh
@Serag Thank you!
Created Account Just to say Thank you
PS : Its a pain to create an account on intel
KLone1
Hi Serag, any solution for asus zenbook duo crashed after update, no access to OS, windows 11 can't detect the ssd, how can I install drivers that are not shown even extracted on usb. Thanks
DfPaxton
Yest another just-made-an-account-to-reply-with-thanks!!
frosales
Serag,
I just had to make an account on intel plataform to thank you for the link
Serag
You’re very welcome i had to because i can relate to how much time consuming and hard to find these files were glad to help anytime
gch90
Thanks Serag really helpfull
JWright
I also created an account just to say thanks.  Huge help, I have been struggling with this for a while.
letmefixit
THANKSSERAG
I MADE THIS ACCOUNT JUST TO THANK YOU YOU SAVED MY LIFE AND MY NEW PC THANK YOU SO MUCH SERAG
ZER0C00L
Just another account created to say THANK YOU Serag!!!
someone needs to give you some free stuff, or a discount, or something
AsbinMaharjan
I was thinking i had to replace ssd. Now its working. I create an account to say Thanks. I am so happy. Thank you so much.
rocmaster
hello  Serag I have used the files you provided and the one in RVT_V19.1.0.1001_PV  has installed but the driver is still not showing
faluuza
Made an account as well just to thank you. Saved hours of troubleshooting, thanks man.
Syllabear
Almost hopeless Thank you Bro!! such a lifesaver here! Commending you to the Community!
Ultimate
how to extract intel or non inet rst to usb
AydenLeitch
I had the same issue, and ended up going down a rabbit hole with Procmon to find where the exe extracted the files.
I then actually went back and checked the documentation, turns out that the extract function is listed in the README, however it does not show up when you run the /? flag.
 Extract driver files from SetupRST.exe:
    - Open terminal in the directory with SetupRST.exe by right-clicking the directory
      and selecting "Open in Terminal" or "Open PowerShell here"
    - Enter the following command:
      ./SetupRST.exe -extractdrivers SetupRST_extracted
Hopefully this helps someone new visiting the post, no discredit to the person who shared the extracted files previously - I'm always a little cautious downloading drivers for untrusted sources.
Cheers,
Ayden
GuestAccount
Created an account just to say THANKS! I'm also cautious with downloads especially drivers....even more so when the goal is for a clean system install!
Thank you so much for doing the work and sharing so we can extract the drivers our selves! Much appreciated!
