Rapid Storage Technology
Intel® RST, RAID
2236 Discussions
F6flpy-x64-Non-VMD.zip and F6flpy-x64-VMD.zip Removed
PhilipYip
There seems to have been an update to the Intel Rapid Storage Technology User Interface and Driver Downloads Page:
https://www.intel.co.uk/content/www/uk/en/download/19512/intel-rapid-storage-technology-driver-installation-software-with-intel-optane-memory-10th-and-11th-gen-platforms.html
Now there is only the option to download the SetupRST.exe. Previously there was a F6flpy-x64-Non-VMD.zip and F6flpy-x64-VMD.zip. These are required to load the F6 drivers during the Windows Setup Screen and the zip format is particularly important when creating Windows Installation Media on another Operating System such as Ubuntu.
Labels (2)
Jocelyn_Intel
Hello, @PhilipYip
Thank you for posting on the Intel® communities. I will gladly assist you here.
There is no need to load the driver during Windows setup. Does Windows show any error when you try to install the RST driver in exe format?
If so, did you try another installer?
If applicable, Can you provide a screenshot if windows requests you the RST driver?
Jocelyn M.
0xAbdullah
f6flpy-x64 intel vmd zip dosyasını nasıl bulabilirim?
AungMM25
Hello Jocelyn ,
                          I would like to request you there was shown
"We couldn't find any drives To get a storage driver click load drive"
when I was reinstall driver. I was looking for many viedo on youtube they say need to download f6flpy but this file already removed from Intel.
PhilipYip
I had another look at this...
Windows IntelRST (Dell Update Package Application)
On Windows double click the Dell Update Package and select Extract.
https://www.youtube.com/watch?v=k0nydQski0o (2:00)
This driver can also be extracted with 7Zip.
Windows IntelRST (Intel Application)
On Windows right click the Downloads folder and select open in Terminal and then type in:
./SetupRST.exe -extractdrivers SetupRST_extracted
https://www.youtube.com/watch?v=k0nydQski0o (3:03)
This driver cannot be extracted with 7Zip.
Ubuntu IntelRST (Dell Update Package Application)
An exe cannot be run on Linux however the Dell Update Package can be extracted using P7Zip... the Linux version of 7Zip.
https://www.youtube.com/watch?v=uhyG6PedBck (9:27)
Ubuntu IntelRST (Intel Application)
An exe isn't really designed to be extracted and P7Zip and can't extract the driver from the driver direct from Intel. It would be easier if these were made available as a zip file... or if Intel made the .exe more similar to the Dell Update Package.
https://www.youtube.com/watch?v=uhyG6PedBck (10:33)
Linux Workaround
The Intel Rapid Storage Technology driver packaged by Lenovo or HP also doesn't seem to extract using 7Zip or P7Zip.
The Dell Update Packages for the Dell XPS 13 series corresponds to the following generations of Intel Processors and can be extracted with P7Zip:
9333 = 4th Gen Intel Processor
9433 = 5th Gen Intel Processor
9350 = 6th Gen Intel Processor
9360, 9365 = 7th Gen Intel Processor
9370 = 8th Gen Intel Processor
9380 = 9th Gen Intel Processor
7390 = 10th Gen Intel Processor
9300, 9305, 9310 = 11th Gen Intel Processor
9315 = 12th Gen Intel Processor
9320 = 13th Gen Intel Processor
The extracted driver from the Dell Update Packages can probably be used in HP and Lenovo hardware with equivalent generations of Intel Processors.
NTOLESKILLS
BONJOUR M. JocelynIntel je  suis confronter au même problème du  "pilotes de la technologie Intel Rapid Storage" puisque mon système avais de soucis je voulais passer a  win11 vue que mon pc est compatible mais je suis bloque a cause ça je peu avoir votre assistance
coordiallement.
MartinJetboy
Hey Jocelyn, can you be a bit more usefull?
people NEEDS the .zip files to install the drivers for the idiotic technology that is Intel Optane so we can install Windows on the Optane SSDs by ourselves.
Why is it so hard to get a straight answer? can you at least say "Intel does not want the customers to handle the .zip files and install Windows by themselves"? or just give us the option to download the .zip files and end the trouble.
PhilipYip
I made a full video recording of the Windows Installation, preparing Windows 11 Installation Media, the F6 Drivers on Ubuntu 22.04 LTS and clean installing. Windows 11 Installation on my Dell XPS 13 9305 (11th Gen Processor) with Intel VMD. It has about 100K views and lots of users followed the instructions specifically regarding the F6 Intel VMD driver:
 https://www.youtube.com/watch?v=Y388W8MaPME
6:11 shows the driver downloaded from Intel in the .zip and not .exe format. This is important on Linux for extraction as Windows Applications cannot be run on Linux.
8:01 shows the RAID Storage Controller being used with Intel VMD in the Dell UEFI BIOS Setup.
10:27 shows that I needed to load the driver to view the SSD.
Jocelyn_Intel
Hello, @PhilipYip
Thank you for the information and the video provided.
I will proceed to do some research about the zip files you need, I'll do my best.
As soon as I have updates, I will let you know in this post.
Jocelyn M.
Nerdtality
This is a REQUIREMENT for Windows Installers that boot from USB! Why did you remove this? There was nothing wrong with the way you had it.
OR3O
Nerdtality
If this isnt fixed, I am hosting my own F6 zip hosting web page and it will explain what intel has done to it's community by removing the zip files.
OR3O
Please do . fully behind you on this one
Nerdtality
Temporary Fix
Download SetupRST.exe
Create RST folder under C:\
run SetupRST.exe from Powershell using:
.\SetupRST.exe -extractdrivers C:\RST
Jocelyn_Intel
Hello, @PhilipYip
Thank you for your time.
These are the steps for the Pre-Installation of the Intel® RST driver, you can actually find these in the ReadMe notes, section 6.3 using the "Load driver" method:
a. Extract driver files from SetupRST.exe:
  - Open terminal in the directory with SetupRST.exe by right-clicking the directory
   and selecting "Open in Terminal" or "Open PowerShell here"
  - Enter the following command:
b. Copy all driver files from the SetupRST-extracted to a USB key media.
c. For Microsoft Windows OS*:
  - During the operating system installation, after selecting the location to install
   Windows, click 'Load Driver' to install a third-party SCSI or RAID driver.
d. When prompted, insert the USB media and press Enter.
e. Follow the prompts and browse to the location of the installation files. Select the
  appropriate ‘.inf’ file (64 or 32 bit). If a supported controller is detected there
  will be no error message. Follow the prompts to continue and complete the installation.
Jocelyn M.
Nerdtality
Oh... Now you submit a solution after I already said exactly what you said? Come on!
Well, thanks for your help? Not really but ok its a start! Now return the .zip file download?
PhilipYip
That workaround can be used if the installation media is being prepared on Windows but it cannot be used if the Windows Installation Media is being prepared on Linux; which is why having the .zip file directly is particularly useful.
yusufadell
I'm facing the same problem on linux qhat if i have the zip file how to install it if the os can't load and suggestions?
OR3O
They did not hve to complicte stuff like this .
Jocelyn_Intel
Hello, @PhilipYip and @Nerdtality
Unfortunately, these zip files are not available at this moment, but I have passed the feedback to the proper team in charge and explained the impact of this for visibility.
Jocelyn M.
PhilipYip
Just to let you know, I have also left Windows Insider Feedback on this issue, suggesting Microsoft proactively slipstream these drivers into the boot.wim and install.wim of Windows 10 and 11 Installation Media:
https://aka.ms/AAk7708
These drivers are as important as Intel network drivers used to give the system basic out of the box functionality, for Windows Installation and Update. Others may also want to upvote the Windows feedback and leave a comment giving details about their system, processor and SATA Operation if they are having similar issues.
