Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
HDD turned into recovery volume.
alek
So that happened...
SSD - Master disk
HDD - Recovery disk
  1. I don't have an option in UI to delete Volume
  2. If i delete Volume as it is, I will lose all the data from my HDD
Is there a way to save all the data from HDD?
SSD has been used only for OS.
If i swap master/recovery. Does it mean that when i delete the volume i will lose data on SSD and then can re-install my OS, without losing data on HDD?
Or are there any other options?
alek
I appreciate your reply, however i have tried both A and B with no effect.
Resetting to factory settings doesn't not remove the volume.
LeonWaksman
Please contact your Original Equipment Manufacturer (OEM) (https://www.intel.com/content/www/us/en/support/topics/OEMs.html) for instructions.
Leon
